Topic: DigiCheck misst andere Peaks als Logic
Dear RME Users,
I am concerned about the following phenomenon: DigiCheck NG 0.90 measures at output 1/2 of a Fireface UFX III (Firmware v.80, Treiber v.3.3.1) under Mac OS 13.6.1 on a Mac Pro 2019 a higher peak level than the DAW, Logic 10.8.1.
This discrepancy did not occur with a Fireface 800 on the same system. All measured values have been identical with the FF800 DigiCheck NG and the older driver.
Here is a video showing my problem:
http://schachttoene.de/Kundenbereich/Tr … repanz.mp4
Thank you in advance for all explanations and solutions.
2 (edited by ramses 2024-03-05 22:33:04)
Re: DigiCheck misst andere Peaks als Logic
Do you mean that? -0,7 in DAW and Fabfilter vs +1.5 in DIGICheck NG?
https://www.dropbox.com/scl/fi/6on80fyi … 6&dl=1
3 (edited by Thiloton 2024-03-05 22:50:25)
Exactly. The DAW measures -0,7 dB FS, DigiCheck measures +1,5 dB FS.
4 (edited by ramses 2024-03-05 23:09:57)
I crosschecked here: "Cubase vs. Fabfilter L2 vs. DC NG levels".
Looks ok to me.
https://www.dropbox.com/scl/fi/x8lvjrd16z5r1eufxszge/2024-03-05-Cubase-vs-Fabfilter-L2-vs-DC-NG-levels.jpg?rlkey=a9d1g2zvhr3c8t13otgnu8h4k&dl=1
Cubase Pro 13.0.21, DIGICheck NG 0.63 Beta, Fabfilter L2 v2.2.0.0
  - ASIO-Guard activated, ASIO-Guard-Level "normal".
  - Preload 2 seconds
UFX III, MADIface 0.9831, ASIO Buffer size: 32 samples @44.1 kHz
5
Thiloton wrote:
Dear RME Users,
You have set DC to show Intersample Overs. Your DAW meters don't do that. Disable that option in DC and the levels will be identical again.
Thanks for the answers!
The solution has bin something different and a much simpler one - as often, the problem sat in front of the screen. I took a look at TotalMix this morning and saw, that my TC Bus was open and measured correctly.
Sorry - but this was my own fault.
http://schachttoene.de/Kundenbereich/Transfer/RME_DC_Meaurement_TM.jpg
http://schachttoene.de/Kundenbereich/Transfer/RME_DC_Meaurement.jpg
http://schachttoene.de/Kundenbereich/Transfer/RME_DC_Meaurement_Logic.jpg
