I read the numbers / specs... but what is the practical, experiential benefit of the expanded range for the ADI-2/4 Pro? Is it at low level listening, high level listening... is the ADI-2/4 better at all levels? I am ignorant to the technical benefits of what that means.
I see that the Auto Reference Levels appear to match from +1 to +19, with the ADI-2 DAC FS not having +24dBu. What is interesting is the Auto Ref readings on the remote app between the two units is different, at the same volume level. What I'm trying to understand is - What is the practical benefit / difference between the 2 units as it relates to that? At that "same volume level" on the main dial, what is the output difference / benefit between the 2 units and, most importantly, why is one sonically better than the other (if so)?
On the ADI-2 DAC FS it is showing -5dBu.
On the ADI-2/4 Pro SE it is showing -1dBu.
ADI-2 DAC FS - Auto Reference Levels
The levels at the XLR output: +1, +7, +13, +19 dBu.
ADI-2/4 Pro SE - Auto Reference Levels
The levels at the XLR output: +1, +7, +13, +19, +24 dBu
