Topic: Advice on how to evolve my RME setup
Hi there,
I am looking for advice on how to evolve my setup.
Currently I am using an UFX (first gen) with an M-1610 connected via ADAT.
As I need more Mic inputs I am thinking about getting a 12mic.
As the UFX ADAT channels are all occupied I think this would trigger an upgrade of the interface to UFX II or UFX III.
Which one would you recommend to get? How would you recommend to connect the devices: MADI? AVB?
Thanks,
Jason
2 (edited by ramses 2024-03-19 18:15:53)
Re: Advice on how to evolve my RME setup
Hi Jason,
one ADAT port supports only 8 channels at single speed (4 @double, 2 @quad speed).
With two ADAT ports on UFX and UFX II you would have only 2x8 = 16 ch (in and out).
Well .. now do the math:
M-1610 16 inputs, 8 outputs
12Mic     12 inputs, 2 outputs
TOTAL: Inputs 16+12= 28 ---> doesn't fit.
There is no flagship interface like the UFX for AVB. The flagship interfaces have a much "richer" feature set compared to an AVB interface (which has basically only USB and AVB port). Therefore, I would recommend getting an UFX III with MADI.
Then you have all the nice features like: DURec, Autoset, standalone capabilities, RoomEQ, Crossfeed, ...
The setup would look like this, you connect the MADI devices one behind the other and get something like a "ring" structure.
PC
| USB III
UFX III *clock master*
|      + M-1610 Pro  *slave via MADI*
|      + 12Mic           *slave via MADI*
MADI
(OM4 or OM3 multimode)
For MADI choose 96k frame. The clock slaves will follow the clock of the master (UFX III).
That is another point where MADI currently still wins. With AVB you need to reconfigure the clock settings on changes on each of the connected AVB devices. With MADI you have it much easier in that regards from operational perspective.
Additional information from my blog
- A few words about "clock synchronization"
https://www.tonstudio-forum.de/blog/ent … ios-en-de/
- Advantages of the UFX+ over the UFX (the old unit that you had)
https://www.tonstudio-forum.de/blog/Entry/68-RME-UFX/
- Advantages of the new UFX III over the UFX+
https://www.tonstudio-forum.de/blog/ent … iii-en-de/
- MADI setup example UFX+ and Octamic XTC
https://www.tonstudio-forum.de/blog/Ent … cber-MADI/
For MADI
Best is to get the SFPs ("transceiver") from RME, otherwise you have to look very closely to get those with correct wavelength and firmware. To prevent any possible issues in that regards, better get those from RME.
In terms of cabling. I would get OM4 multimode fiber cables. About the same price as OM3, more recent, better looking standard color (violet).
Get OM4 multimode fiber cables with the correct plugs, you need between
- UFX III and M-1610 Pro: SC to LC
- M-1610 Pro and 12Mic: LC to LC
- 12Mic and UFX III: LC to SC
You get patch cables (duplex cables) from 0.5m up to 30-50m.
Everything longer in a building is not a "patch cable", this is in-house cabling between patch panels.
You need most likely only "patch cables" between the devices.
The max cable length for multimode fiber between each of the devices in this "ring" is 2km! Quite flexible wink
If you have all in a rack you do not need longer than 0.5 - 1m.
Do not bend fiber cables too much.
many thanks Ramses for the elaborate answer!
You're welcome :-)
