Topic: bug: TotalMix or the device recalls the snapshots wrong?
I have quite often problems with Totalmix which is showing something different than the card's mixer is actually doing. Like here - the Mic 10 shows in AN6 out and ADAT 9/10 out but it is turned off.
I've tried to save the snapshot to a file and recall it - no changes. The situation goes back to correct state as soon I manually drag the Mic 10 fader. (Sometimes I need to use the pan or width control, too.)
Another scenario. (Setup: I have ADAT9-16 Out plugged back to ADAT 9-16 In what might end in a feedback overload if used incorrectly. Please, don't tell me I can use a loopback in totalmix, I know it. In current situation it only shows me there's a inconsistency between app and hardware.) After clicking Options -> Reset mix -> TotalMix reset I have a overload on ADAT 9/10 and ADAT 13/14 and on some ADAT outs, but all the input faders are down! Also the "Clear Submix ADAT 15/16" doesn't change anything (except turning off *SOFTWARE PLAYBACK* ADAT 15/16 on this submix but of course this is unimportant here).
This UFX is DSP-SW Version 1.63, and the Totalmix is 1.75, but I have a lot of RME stuff (FW800, UFX/UCX and Digiface) and this inconsistency happened before, not only on this UFX. It also happens on MacOS. Most of the time, it can be fixed with manually touching/dragging all the input faders out of their position and back. At the moment I can go back to the screenshot 2 situation with "totalmix reset" or with recalling some of the snapshots. But "my main snapshot" (the 2nd one, kb_HOME) doesn't have the ADAT Inputs opened (what cause the loopback overload).
The Matrix view also doesn't show anything helpful (it is consistent with the Mixer view).
