Topic: Which Fireface has latest AD/DA converters and steady clock?
Hi all,
I am wondering which Fireface model has both, the latest set of AD/DA converters and the latest implementation of steady clock fs with the most effective jitter suppression.
Looking at the technical data, it seems that 802fs, UFX II (new hardware rev) and UFX III have the latest AD/DA converters used (THD+N <-110dB). UCX II has THD+N performance 6dB worse.
Regarding steady clock, 802fs and UFX III seem to be state of the art, and UFX II seems to be 2 generations behind (30dB jitter suppression >2,4kHz for UFX II vs 50dB >1Hz for 802fs and UFX III). Is this correct, or was steady clock also revised in UFX II hardware revision 2023?
Reason for asking: I am looking for best AD/DA performance and jitter suppression for my use case and prefer a unit with display and knobs for standalone operation. UFX II would be the "sweat spot" as I do not need the feature set of UFX III, however, I do not want to invest in outdated technology.
Thanks for your feedback.
Best regards, Mark
ADI-2 Pro FS R BE / UFX II
Minidsp SHD
Neumann KH120, KH310, KH810 / Audeze LCD-X
