Topic: RME ADI-2 Pro FS R Black Edition setup with Audient ID22
Hey guys, just going to pull the trigger with the RME ADI-2 Pro FS R Black Edition and i would like to setup it with my Audient ID22
The goal is to be able to record my hardware machines to Audient / Daw Ableton live,  then listen the audio by the RME Adi2 interface.
So ,the Neumanns kh 120 monitors to RME ADI outs but not sure how to connect the Audient/ RME here with this configuration
Does anybody have a similar setup that can give a help ?
Peace out
Re: RME ADI-2 Pro FS R Black Edition setup with Audient ID22
Toslink cable from Audient to ADI-2.
ID 22---Optical Out------------TOSLINK--------------->ADAT IN---ADI-2 Pro FS---AN1/2--->Monitor
        \---Optical IN<------------TOSLINK---------------ADAT OUT----/             \----AN3/4--->Phones
Clock Master        Clock Slave
See my blog for the setup of the ADI-2 Pro:
Manny thanks for the help guys
Unfortunatly it didnt arrive yet. Hope it next week
I replied to your other thread and aren't really sure why you'd want the ADI-2 Pro.  Audient gear is really good... I've got several of their mic pres in our studio facility.  Any differences in D/A conversion between the two is likely to be un-noticeable.
_____________________
Eric Seaberg • San Diego, CA • USA
A.E.S. • S.M.P.T.E. • S.P.A.R.S. • I.E.E.E.
Manny thanks for your answer !
Well , mainly because i thought that it would give me much better listening from my setup.
Also im planning to do some mastering in the future
Just received the Rme Adi 2 pro black and im delightfull with it, superb sound quality !!
Now have some hardware and wanna print to Ableton Live.
My current setup is the Adi 2 pro + Audient ID22 and are connected by toshlik.
Audient is slaved to ADI and hardware comes in Audient 1/2 INS but cannot rec it in Ableton, what am i missing here ?
Does anyone has same hardware that can give a help please ?
How are you feeding Ableton? I assume you're NOT using the USB on the Audient, but USB on the ADI2?  This would be setup (on a Mac) in Audio/MIDI setup. You'd pass the SPDIF from the Audient through ADI2 using USB as your record option. Have you setup the ADI2 as multi-channel or simply stereo?
Ups, i am. It was my setup before Adi arrived.
Ok, so i should disconnect usb Audient to Mac ?
Just finish rebuild other studio and now starting to connect everything.
Took a look at your blog and still have many questions eheh
Ok Ramses , so based on your answer i must connect the RME to the Audient by toshlink.
One thing i dont undertand is RME clock is supposed to be better , so why not connect the Audient in slave mode ?
Other thing i dont understand and someone here mencioned , should i have usb from both interfaces connected to my computer ?
I have hardware synths i usually print in Ableton live, witch interface ins should i use to rec ?
Thanks for your patience
