Topic: ADI-2 DAC FS DoP Recording Error with VinylStudio on Mac OS
Hi
According to the manual
17.4 DSD Record
Via USB the SPDIF inputs can record not only PCM but also DSD (DoP).
I'm connected with Fireface400 via ADAT to the ADI-2 DAC FS and I'm trying to record DoP with VinylStudio witch support DoP
( in VinylStudio DSD64 (DoP) is selected ) and VinylStudio give this message
The incoming audio (PCM) does not match the setting in the DSD Input dropdown (DSD). Please either:
a) change the dropdown to match the DSD setting on your input device, or
b) change the DSD setting on your input device to match the dropdown.
Then click Retry.
You may also need to set the recording level slider to maximum when making DSD recordings.
The Main Device State show the following
On the ADI-2 DAC FS I see the following
Please let me know if I'm doing right with the following settings ?
Thank's, Looking For Advice
