Re: Room EQ, Crossfeed, Triple SPDIF - UFX+, UFX II, UFX III, UCX II
Man, I’m still waiting and reallllllyyyy hoping for the 802fs Room Eq…
152 (edited by Mark_S 2024-04-03 16:41:01)
First of all: great to have the Room EQ features added, makes a Fireface interesting for my use case!
Some questions:
- Are all nine Room EQ PEQs usable below 300 Hz?
- Do all these PEQs have Q up to 9.9?
- What is the frequency resolution of these PEQs, I.e. can I adjust the middle frequency per single Hz or per 10Hz or...?
Reason for asking is that my ADI 2 Pro FS R BE has quite some restrictions regarding PEQs making this feature quite uninteresting for dealing with room bass resonances.
Feature request: would it be possible to add a bass mono feature for vinyl playback like the one implemented into the ADI 2/4 Pro SE? This could be just another crossfeed option for two analog inputs (stereo pair). Would be useful to reduce rumble and noise.
BR Mark
ADI-2 Pro FS R BE / UFX II
Neumann KH120, KH310, KH810 / Audeze LCD-X
Some questions:
Yes
Yes
**Single freq up to 200Hz then in steps of 10Hz up to 2kHz, then steps of 100Hz
**(please correct me if I am wrong)
Thank you Matt.
Sounds very usable, so I will probably swap my minidsp with a Fireface.
BR Mark
155
UCX II, Win 11, driver 1249, TM 1.93, DSP 31.
One pair of Monitors is connected via AES. RoomEQ is activated for 9 bands. When setting up the second, 3-band EQ, on this channel (AES), at some point there was a strong pop and the sound on the monitors disappeared. Now the sound in the monitors is only audible if the 3-band EQ is disabled. When turning the 3-band EQ on/off, the same pop is constantly heard. When changing the volume level of this AES output channel, every step is a bang. If there is no signal from the player, then the 3-band EQ can be turned on/off without a pop. With 3-band EQ turned on, if I turn on the player, a pop sounds and there is no sound. Channel indicator are working. Disabling RoomEQ on this channel does not change the situation.
(On the second, analog output channel, both channel equalizers work well.)
WHAT COULD BE THE PROBLEM?
156
Can you send us a workspace with all settings set so that the sound is lost?
Dear Matthias, I sent it in a personal message to your email.
If you order, I will post it here in a message on the forum.
Thank you!
158
Files received, thanks. We'll check.
Now that was easy wink
Change Q in band 3 (20 kHz) from 0.4 to 0.5 and it will work. We check how to fix this.
Surprisingly, this fixed the problem smile,
Thanks a lot, Matthias!
161
Let's continue here:
https://forum.rme-audio.de/viewtopic.php?id=39428
