Topic: Babyface (original) not detected after use of USB extension cable
Hello everyone,
For the first time in almost 10 years of heavy use, I tried to plug my Babyface through an USB extension cable... Big mistake ??
Since then, the Babyface is not recognized at all on any PC (Windows in normal mode nor Linux in class compliant mode), with or without the extension cable, while its powered and working normally at first glance. I can even power a static mic in CC mode and see the input signal with the LEDs.
However, from the computer it's just as if nothing is plugged on the USB port. A command like "lsusb" on Linux won't show anything.
I used that extension cable on the "big one" of the two plugs from the dual USB cable originally provided with the Babyface.
After that (and after I noticed it wont work anymore) I tried to plug the Babyface through another simple USB cable, but it showed me angry red LEDs so I thought the cable was not compatible. I haven't tried with another dual USB cable.
Seems unusual as I read that people are using the Babyface with extension cables with no issues on other forums.
Did I just brick my mighty Babyface ?
