Topic: UCX II Volume & Buffer size
helloe i have 2 question
1. sometime i change the buffer size for example from 1024 to 96 but in the daw when you see the miliseconds its not change and the latency is still on (work on Cubase)
2. about Volume - I work around -30 volume in the interface (UCX II) sometime i play things and i hear like the volume gets lower (same volume in interface) and then i turn off the interface and and turn it on again and its fixed ( ts happend a lot) how can i make it stop? there is some setting that do that to keep my ears? some cellings?
