Topic: driver and connection recommendation for UFX+ / M1 Max / Sonoma
hello, apologies if this has been covered over and over, but i think my question is a little bit more focused..
i just bought an m1 max MBP, running current version of sonoma, and i want to get my UFX+ up and running.
if i understand correctly, i will need to install the kext driver to make sure my firmware is up to date on the UFX+..
however, there remains the question of whether to use the kext or driverkit drivers for everyday use. i also can choose between USB and TB for the UFX
i use ableton for pretty much everything, i don't care about browser audio, i don't need to stream anything concurrently or run any aggregate devices.
i do occasionally work in multichannel audio (4, 6, 16+ channels), and do use ADAT and sometimes MADI.
i have one (notable) recommendation to use the TB connection + driverkit - however i thought the kext driver was supposed to offer more stability (for the interface) - just trying to get clarification.
any insight/anecdotal thinking is helpful, thanks.
