Topic: How to control Monitor levels with ARC
Hi, I just purchased a ucx along with the ARC
If I am doing this correctly, I've installed the driver and totalmix on my window 7. I've inserted my monitors through balanced line out 1 and 2. Here is my totalmix when playing audio.
Now with the ARC, the rotary button controls the main output, which for me only controls the headphone volume and not my monitors. There are two faders AN 1/2 hardware output and An 1/2 software output. Should I set the hardware output at 0 and adjust the software playback fader?
Either fader that you recommend, I would like to use my ARC's rotary button to control my monitors two monitors. However, I am not sure how to do it even after reading the manual. Please excuse my lack of tech savviness.
