Topic: TotalMix via UCX Fireface II - Initial speaker set up, please help!?
I have a RME UCX Fireface II, and I have done the following, partly by default, and my own intervention, and want to know if my reasoning is correct (I suspect it's highly likely to be awry)?
I have a 2.1 (L+R monitor plus Sub) set up. I've routed the analog outputs of 1/2 on the rear panel of the RME to L+R monitors, and I 'believe' via the standard accommodation of total mixes 'submix' default settings this is hardwired (via default software settings) to stereo output on main? Can some one look at my screen shot and tell me if I'm mistaken https://ibb.co/kKTrL61?
Also if Total mix is hardwired as mentioned via submix how do I get under the hood to pick out 'L' & 'R' speakers separately? As there is no way to differentiate (at least for me) how much signal is going to the Left Monitor and how much signal is going to the Right Monitor, apart from the L/R dial (I appreciate the dial may be the full extent of analysis, but I'd like to be sure)?!
Lastly as the Sub output is routed via hardware output 3, and the standard readout of outputs is 3/4 so I've set outputs 3 and 4 to Mono, and am getting muted sub signal play back, my questions are (a) is my reasoning correct, and (b) how do I get a louder signal to my sub?
Sorry to be an encumbrance, I'm highly new at this, and just got my speakers after a few weeks of running the UCX Fireface - II off headphones!!!
Thanks in advance, with a degree of postulated trepidation :I
