Topic: Babyface Pro FS AS1/2 does not loop back to SPDIF/ADAT(1+2)
I have connected a Babyface Pro FS to a Windows 10 PC and set SPDIF/ADAT(1+2) as the Playback Default Device.
When I Loopback AS 1/2 of the Hardware Outputs in TotalMix, it should be looped back to SPDIF/ADAT(1+2) on the recording device, but there is no input.
Instead, it is input to AN1/2 of Software Playback on TotalMix (I have not copied and pasted channels from AS 1/2 to AN1/2).
I confirmed that when I set AN1/2 as the Default Device and Loopback, it is input to Analog(1+2) on the recording device.
I also confirmed that if you copy and paste other channels to the "Main" channel of TotalMix and press the Loopback button, the channels are input to Analog(3+4) on the recording device.
Is it normal that the Loopback behavior is different only for AS1/2?
Or is there some setting that I'm missing?
This may be a basic question, but I would appreciate your help.
