Audio AG Support wrote:You can purchase another Alphalink and daisy chain both devices to the MADIface you already have. It can handle 64 channels in 44.1 kHz and 48kHz. No need fo second MADIface. Unless your record on 96Hz or higher.
Three devices per driver are tested by RME, theoretically more is possible.
But then you need to test / check whether your PC / Apple is capable of handling this many I/O channels.
You should take care, that not two interfaces are connected to the same USB controller.
I am not sure if / how you can check that on Apple.
Remember, all I/O channels are being transferred no matter whether the audio channels are in use or not
(only exception to this rule of thumb the HDSPe MADI FX driver which optimizes this by grouping channels in chunks of 8 ports and only if at least one channel of such a group of 8ch is in use the driver allocates resources for those 8ch).
As RME mentioned, MADI supports up to 64ch at single speed (44.1/48 kHz) and you can chain the devices at one MADI port.
For two of those devices, the port capacity on one MADI bus is fully sufficient.
