raydat clock master, rest clock slaves.
See also my blog article: https://www.tonstudio-forum.de/blog/ent … ios-en-de/
PC
RayDAT(cm)---ADAT1------------------> Ferro (cs via ADAT IN)
---ADAT1<------------------
---ADAT2------------------>
---ADAT2<------------------
---ADAT3------------------> ADI-2 FS (cs via ADAT IN)
---ADAT3<------------------
---ADAT4------------------->ADI-2 DAC FS (cs via ADAT IN)
From operational perspective nice, because the clock slaves follow the clock of the master which is set by the DAW/application.
Otherwise if you prefer to have steadyclock FS as clock source you can use ADI-2 FS as clock master.
But then you have to set clock in the application and at the ADI-2 FS.
As the ADI-2 DAC FS has no digital outputs you can't use it as clock source, but doesn't matter, ADI-2 FS has also FS clock.
PC
RayDAT----ADAT1------------------> Ferro (cs via ADAT IN)
----ADAT1<------------------
----ADAT2------------------>
----ADAT2<------------------
----ADAT3------------------> ADI-2 FS (cm)
-cs-ADAT3<------------------
----ADAT4------------------->ADI-2 DAC FS (cs via ADAT IN)
