Topic: clocking the digiface usb
I clock my entire setup from Big Ben via wordclock. I now want to incorporate a Digiface USB into my setup to replace an FF800. The part of the setup that has to change and which I would propose is the following (which mimics the present setup with the FF800 as closely as possible)
Big Ben -------- adat clock out -----------> adat port 4 in Digiface
Big Ben -------- WC out -------------------> WC in 192 Digital
Digiface adat port 1 <--------------- adat in and out ---------------> 192 Digital first adat port
Digiface adat port 2 <--------------- adat in and out ---------------> 192 Digital second adat port
I should point out that the 192 Digital is part of a Protools HD setup on a MacPro running Protools. The Digiface will be connected to a second MacPro with Logic serving as a supersynth sending sound to the MacPro with Protools via the Digiface and the 192 Digital.
The proposed setup worked flawless with the first line (Digiface and adat clocking) replaced by Big Ben --> WC out --> WC in FF800 and the Digiface replaced by FF800 in lines 3 and 4.
Is the proposed setup above the right replacement?
Thanks for any info, cheers, Bob.
