RME Support wrote:Sure, I was looking at a setup that includes the already existing DF USB... A random cheap device that can throw out Word Clock might be cheaper and still allows a more mobile setup with e.g. Digiface and just one converter. And you have the phones output.
Yes, thats a valid point, RayDAT is a fully digital card and he wouldn't have anything for the monitoring.
He could add ADI-2 DAC FS or ADI-2 Pro FS R BE for monitoring, but this will cost a few bucks more
plus the Sonnect expansion case ..
Well then he can already think about getting 802 FS or UFX II, but then he can connect the Audients only at single speed.
Or 802 FS (or UFX II) and one audient @single speed, if this would be sufficient from the amount/type of ports.
Then it would be again an USB based version and he wouldnt need a TB expansion case.
Well, your solution will be cheaper, but I see certain limitations, only 2x analog I/O is a little bit less ...
OK, he could add an analog monitoring controller ... to get at least active monitors and phones output ...
Many possibilities ..
