Topic: Using ADI-2 Pro FSR BE as digital preamp
Hi there - I’m trying to use the ADI-2 Pro FSR BE as a digital preamp. My setup:
- Streamer connected to USB input (raspberry pi)
- Phono stage connected to optical input (parks audio waxwing)
- D&D 8C active speakers connected to AES output
My goal is to select between the USB/Optical inputs and leverage the RME for digital volume control, loudness application, EQ, etc. Does anyone have any suggestions on how to configure this setup? I’ve used the ADI-2 with many other setups in the past and found it easy to configure what I needed. After much experimentation and reading the manual, I can’t figure out how to get this setup working properly. It’s easy to get either USB OR Optical to work, but I can’t figure out how to flip between the two with the remote.
Any suggestions on which mode should I be running in or other key settings I may be missing?
Dave
