Topic: Totalmix Remote Sync Channel Layouts
I'm loving the Totalmix remote on iPad as monitor controller for some time now but one described function seems to elude me. The Sync Channels function.
Ideally I simply want the iPad remote to mirror TM on my Mac. Change or select something on iPad or on the Mac directly and the change or selection is mirrored on the other platform. I can get this to work for snapshot selection, layout presets and fader movements/ other control movements but it doesn't seem to work for output/ subgroup selection.
Is this me only or is this a current limitation?
__________________________
Paul Najar
Jaminajar Music Production
www.jaminajar.com
Re: Totalmix Remote Sync Channel Layouts
That's the way it is designed. Total 'visual'  mirroring does not makes sense in nearly all use cases. It would interfere with the use of another person, or the same person when used intentional as second view setup.
Thanks for the explanation Matthias. Makes sense. I had not thought of that. This speaks to more of a multi remote client workflow.
You probably don’t ever get asked enough but a single user use case (like me) with a preference in remote like “Remote selection follows desktop” may be an idea at some point?
Kind regards
Paul Najar
www.jaminajar.com
See TM FX 1.96 here:
https://forum.rme-audio.de/viewtopic.ph … 22#p221522
Thanks so much for this Matthias and nice work in general on the new totalmix release.
Paul Najar
www.jaminajar.com
Hmm, did I speak too soon on this? On iPad Remote I could not see this option. Has it appeared in that version yet or is it just for Mac/ Windows at this time?
Paul Najar
www.jaminajar.com
You may have noticed that on AppStore for iPad - TM Remote 1.41 is the latest Version atm...
So, i think, you'll have just to wait until 1.42 will be available for iPad.
In the meanwhile, you could play around with the TM Remote Mac/Win Version, offered in the TM 1.96 Thread.
“Do It For Her”
