howlback wrote:ramses wrote:I googled for SSL OctoPre but couldn't find such a product, URL, please.
Can you please provide a screenshot of the MADIface driver settings for both cases?
Sorry, SSL PureDrive Octo
https://solidstatelogic.com/products/puredriveocto
You say you configured the SSL Pure Drive Octo to act as clock master.
Then you have to configure the UFX III as clock slave.
If you connected the TOSLINK cable to the UFX III
- ADAT1 .. did you set clock source to "Optical 1"
- ADAT2 .. did you set clock source to "Optical 2" in the MADIface driver settings?
Are both ADAT I/O Ports (ADAT1 and ADAT2) set to ADAT protocol in the MADIface driver settings?
Could be the case that protocol recognition of ADAT inputs is not automatic (like with the BBF Pro) and depends on the settings of the ADAT outputs. I am not sure whether clock sync works, if the the protocol is not proper set to ADAT.
So ensure that protocol is set to ADAT for ADAT1 and ADAT2 out in the MADIface driver settings.
Can you please provide a screenshot of the MADIface driver settings in both cases?
To be on the safe side plug the TOSLINK cable on the SSL side to the 1st ADAT output which is labeled with 1..8 and 1..4.
