Topic: RemoteFish not detecting 2 Pulse 16MX on MacOS Sonoma
Greetings,
I recently switched over to MacOS from Windows 10 and for some reason RemoteFish no longer detects both of my Pulse 16MX ? the optical cabling is the same as it was before on PC and RemoteFish showed me both of my units.
Anyone experience this issue ?
My UFX III still sees all of my MADI I/O so it does seem to work ok, I have to test it out to confirm.
I"ll post in the FerroFish forum as well, just thought I'd ask here in case someone else has seen this issue / resolved it.
2 (edited by waedi 2024-08-03 15:20:14)
Re: RemoteFish not detecting 2 Pulse 16MX on MacOS Sonoma
Totalmix
menu Options / Settings
change Midi Ports to 3 or 4
Also use the same Midi Port in the remotefish.
UFX lll user manual page 47 : Midi over Madi
https://i.ibb.co/yRDg28K/midimadi.jpg
Thank you very much.. I will try this as soon as I can.
Cheers
I am using a Pulse 16 MX as well (with a UFX+ via MADI) and Remote Fish often doesn't connect.
Luckily I rarely need Remote Fish and it is working good enough for initial setup and occasional setup changes.
