Topic: FF800 digital feedback and glitchy audio
Although there are similar posts relating to this issue, I've yet to find a permanent solution so am hoping if outline the problem and all the moving parts, someone here maybe able to help me narrow down options.
I'm running a Mac Pro 5,1 with Big Sur 11.7 (installed by Opencore Legacy Patcher) which my FF800 connects to via FW. Prior to upgrading from 10.x, everything worked fine, now it's hit and miss if the Mac and FF800 play nicely. Once booted, although the FF800 host light shows connection and the TM & Settings apps load, when any audio is played from the Mac, there is a digital overload/feedback that lights up all the channels on TM etc. Equally, if I boot Cubase, when the ASIO is engaged the same feedback occurs. Should add, this happens 6 out of 8 boot ups and doesn't seem to follow any pattern
I've trashed and reinstalled all the relevant FF800 drivers (as advised on this forum) from 3.30 up to the latest 3.41 and the 2.77 FW. I've swapped cables, tried different FW ports and recently bought the https://www.startech.com/en-gb/cards-ad … pci1394b_3 FW card as it was suggested in another post relating to the same issue. The latter didn't help as although the Mac recognised the card, the FF800 didn't. The red host light stays illuminated. This could be for a myriad of reasons but for the time being, I'm just concentrating on finding an answer for the feedback.
It looks like something is going wrong in the transfer of audio between the Mac and the FF800 as it's recognised and TM/Settings shows it's connected so it's looking unlikely to be a FW driver issue otherwise the FF800 wouldn't be recognised. This is one of the reasons I've not tired the Kernal panic by MC https://forum.rme-audio.de/viewtopic.php?id=33277
I'm aware that we're talking about a 20yr old device trying to work with a 8yr old Mac running an OS X it wasn't expected to run but there are users out there making this work. Unfortunately, they've not responded and or posted their solutions/workarounds.
So in conclusion, if anyone has a suggestion I've yet to try, please let me know and if you need any further info.
Thanks,
McD
FireFace 800 3.41 / 2.77
Cubase Pro 12 & 13
