On Mac? And you use Totalmix?
If yes, should be quite easy:
1) switch between the Babyface and the Digifaceusb:
- In TM open your BF and and DF at the same time (you should get 2 windows)
- In TM select Window - Merge all Windows (you should get one Window with two tabs)
-> with ^+TAB (Ctrl+TAB) you can switch between the BF and DF Tab(window)
2) controlling both (BF and DF) with one Mackie Controller
For both Tabs (BF and DF Units) select exact the same MIDI Settings for each unit: in TM: Options - Settings - MIDI:
- F.ex: Controller 1
- Checkbox "In use" enabled
- the same MIDI IN/Out Port (according to your your XTouch)
- Enable Protocol Support
- enable Checkbox "Disable MIDI in background" - this is the most important, as only the active tab will/should communicate with your xTouch
- rest here according to your needs
- click OK
- in TM: Options - Enable MIDI Control
Should work now.
“Do It For Her”
