Topic: Fireface 400 x Behringer ADA 8000 x Ableton x PC x NOT WORKING YET
Dear Technicians,
Im very thankful, if someone can help me to get the ADA 8000 running with the FF 4000 in Ableton.
The Issue is:
I dont know how to get Sound through the ADA 8000. I dont know how to route in Totalmix. I dont see a signal in Totalmix.
What I already did:
Word Clock: Is connected, FF 400 is the Master, The Cable is connected to the "Word Out" in the FF 400, at the ADA 8000 its connected to "WC IN"-Setting.
Fireface Settings Mask: Optical: ADAT, Clock Source: Internal. (Input Status says: Word: No Lock, ADAT: No Lock)
FF 400 Hardware: ADAT Light is Green and constantly shining, next to the Word In/Outs is a "75" and theres an orange light constantly shining.
Issue: I want to use Inp: 1, 2,3 and Out 1,2,3 of the ADA 8000, and use them in the Daw (Ableton).
Question 1: How do I have to route them in Total Mix and Ableton?
In Ableton I got 18 Mono Inputs "active" in the audio-settings. Furthermore, there are 18 Outs "activated".
Question 2: Which of those Numbers are now connected to which Element in the Total-Mix-Mask?
Thanks a lot for your help.
Best, Felix
