Topic: RME Dante disappeared from Dante Network. No more Dante?
New user and running setup tests on this. RME Dante setup went fine and test recordings yesterday were fine. Booted system up today for all-day session. Have error log that shows RME Dante firing Warnings and info. Then it was gone. The odd thing... The attached mixer (using direct Primary connection to RME) was still on Dante Control and reporting fine.
Dante Controller does not see RME Dante box... but Windows does, and audio plays out headphone jack. Have done basic disconnect, reboots, reseat USB, check drivers (which still function fine). The RME Dante does still seem to be clocking from the mixer (sample rate grey out). RME had disappeared from Nuendo but is available to Nuendo after reboot (and working with DAW).
But... cannot get unit back into Dante Control. Thoughts?
Log here
Dante Controller Event Log version 1.0.0
2024-08-30 13:47:39 EDT 1725040059996 Information "Digiface-Dante" "Timed out 3 times sending message 'UpdateRxChannels' to Digiface-Dante, giving up."
2024-08-30 13:47:24 EDT 1725040044262 Error "Digiface-Dante" "Device Digiface-Dante has been regained sync"
2024-08-30 13:47:24 EDT 1725040044262 Error "Digiface-Dante" "Device Digiface-Dante has been unmuted after mute."
2024-08-30 13:47:22 EDT 1725040042133 Information "Digiface-Dante" "Timed out 3 times sending message 'UpdateRxChannels' to Digiface-Dante, giving up."
2024-08-30 13:47:19 EDT 1725040039950 Information "Digiface-Dante" "Timed out 3 times sending message 'UpdateTxFlows' to Digiface-Dante, giving up."
2024-08-30 13:47:02 EDT 1725040022925 Error "Digiface-Dante" "Device Digiface-Dante has lost Clock sync."
2024-08-30 13:47:02 EDT 1725040022925 Error "Digiface-Dante" "Device Digiface-Dante has been muted."
2024-08-30 13:47:00 EDT 1725040020980 Information "Digiface-Dante" "Timed out 3 times sending message 'UpdateTxFlows' to Digiface-Dante, giving up."
2024-08-30 13:46:58 EDT 1725040018746 Information "Digiface-Dante" "Timed out 3 times sending message 'UpdateRxChannels' to Digiface-Dante, giving up."
2024-08-30 13:28:09 EDT 1725038889485 Error "Digiface-Dante" "Device Digiface-Dante has been regained sync"
2024-08-30 13:28:09 EDT 1725038889484 Error "Digiface-Dante" "Device Digiface-Dante has been unmuted after mute."
2024-08-30 13:28:01 EDT 1725038881491 Error "Digiface-Dante" "Device Digiface-Dante has lost Clock sync."
2024-08-30 13:28:01 EDT 1725038881489 Error "Digiface-Dante" "Device Digiface-Dante has been muted."
2024-08-30 13:28:00 EDT 1725038880945 Information "Digiface-Dante" "Timed out 3 times sending message 'UpdateRxFlows' to Digiface-Dante, giving up."
2024-08-30 13:27:56 EDT 1725038876486 Information "Digiface-Dante" "Timed out 3 times sending message 'UpdateRxChannels' to Digiface-Dante, giving up."
2024-08-30 09:16:10 EDT 1725023770577 Warning "" "Device 0004C40A3B5D (device name not known) is now a primary leader"
