1
Topic: MADIFace XT II setup slot bug?
I think I'm running into a bug on the MADIFace XT II, but I wanted to sanity check that I'm not just misunderstanding something.
First off, I'm running my MADIFace in USB Class Compliant mode (not using custom RME drivers). I use the custom RME drivers to set up the mixes with TotalMix, but then for actual usage I switch it to USB CC mode.
I have a "passthru" mix in setup slot 1/6 that just sends all my instruments directly to my speakers.
I have a "performance" mix in setup slot 2/6 that routes the signals from each instrument through intermediate boxes (like distortion units, delays, mixers, etc.) and then sends the processed signal to the speakers.
I can switch between these two modes no problem *if the USB cable is unplugged*.
Once the USB cable is plugged in (checked with both laptop and ipad), loading setup slots stops working correctly.
Starting in 1 and loading 2 doesn't seem to do anything.
Starting in 2 and loading 1 seems to leave the intermediate boxes in the mix, but messes up the output gain settings.
Anyone else able to reproduce this issue?
Re: MADIFace XT II setup slot bug?
Totalmix 1.97 B2 is out since yesterday.
You may test with new snapshots with minimalistic routing just for test, made with the new Totalmix of course.
It's possible one or both snapshots are broken ?
Download the new Totalmix from here :
https://forum.rme-audio.de/viewtopic.ph … 26#p223726
3
None of that, and we just discussed this topic: memory slots are incomplete as they are for stand-alone mode, not online. They don't include playback routing (no playback in stand-alone). So using those memory slots for CC mode will not work, and that's why they are not made available.
More here:
https://forum.rme-audio.de/viewtopic.ph … 53#p224453
