Topic: ADI-2/4 PRO SE - Can be improved with any external component?
Good evening.
I am a user of the ADI-2/4 PRO SE DAC in a home HIFI audio installation.
I am very satisfied with its performance.
It is connected with an AUDIOQUEST DIAMOND USB A-B cable to a MAC-MINI. The MAC-MINI receives a fiber optic signal from a commercial router from the telephone company.
A friend of mine is insisting that I should investigate including an element in this chain that improves the synchronization and cleanliness of the audio signal that reaches the DAC.
He has spoken to me about audiophile switches, also about external reclockers, DDC converters, etc.
According to him, the weak point of my chain is using a USB connection between the MAC-MINI and the DAC because he considers that this connection is not audiophile and could lead to various problems that the DAC cannot solve.
On the other hand, there is another friend who recommends that I continue as I have been. This person is the one who recommended that I buy this DAC. According to him, the technology incorporated in this DAC is so good that it does not need external help to purify and re-clock the signal
In short, as experts that you are, I am going to need your advice on this matter.
If you think I can improve the final audio by adding some component, I am willing to listen to your suggestions.
Thank you very much in advance for your help.
Greetings.
