Topic: Fireface UCX II MIDI SYNC setup with hardware TR8S
Hi Everyone,
After spending a lot of time researching and trying out different solutions for almost a year, I figured I’d reach out here to see if anyone else has faced the same issue and might have some advice or recommendations to make things easier.
Last year I bought the Fireface UCX II, hoping it would solve all my problems , but I'm still running into the same issues I had with my previous, much cheaper audio interface.
My Setup:
Windows PC / MacBook Pro (Intel, 2018)
Ableton
Fireface UCX II
TR8S Drum Machine
What I'm Trying to Achieve:
Studio Setup: I want to sync my TR8S with Ableton on my Windows PC for production purposes. I like using the TR-Editor to easily control the TR8S while working.
Live Performance: I want to sync my TR8S with Ableton on my MacBook Pro for live performances.
The Problem:
In both setups, I face the same issue. After setting up the clock to send from Ableton via MIDI or USB to the TR8S and adjusting the delay to sync everything perfectly, I notice that after a few minutes, the sync drifts, and the drum machine is no longer in sync.
During my live performances, I’ve had to open Ableton's settings mid-set to adjust the MIDI Clock Sync Delay to get everything back in sync (which is super stressful), Nudge my TR8s or I’ve had to stop and restart the project to reset the sync.
What I’ve Tried:
Syncing via USB instead of a MIDI cable.
Syncing via a MIDI cable instead of USB.
Sending audio from the TR8S via USB + use USB to sync midi clock.
Sending audio via TRS-Cable into the interface and syncing midi clock via USB.
Sending audio via TRS-Cable output and syncing clock through a MIDI cable.
Changing the MIDI sync type to song or pattern mode.
Ensuring a low buffer size in Ableton (128 samples).
Confirming both TR8S and Ableton are set to the same sample rate.
What I’m Hoping to Get from This Thread:
I know MIDI sync issues are common, and I was hoping the RME Fireface UCX II’s SteadyClock FS feature would help solve this problem. I’m looking for advice on how to properly set up both my studio and live performance setups with the Fireface to keep my TR8S in sync.
Has anyone with a similar setup found a solution for MIDI drifting? Any tips or tricks I might not know about? Is there anything in the Fireface settings I need to do? Or is there any additional gear I’d need to ensure everything stays in sync?
Hope I can get some more insight into my issue and thanks a lot to everyone taking the time to read this!
Best
Michael
