Topic: ADI-2/4 PRO SE to KH 750 Sub
I know the easy thing to do is to connect my BNC RCA cable to the red SPDIF OUT.  Is there a one cable connector that I can purchase or have made in order to avoid using the adapter?
Right now I have a USB-2 to computer
TRS 3/4 into a phono stage
Would like to know what options I have for a single cable into the Neumann KH 750 sub which uses a BNC
Thanks!!
Re: ADI-2/4 PRO SE to KH 750 Sub
https://www.thomann.de/de/pro_snake_bnc … dapter.htm
https://thumbs.static-thomann.de/thumb/padthumb600x600/pics/bdb/_16/165673/13272666_800.jpg
Connecting the sub analog is also an option, then ADI-2/4 can perform D/A conversion using auto reflevel.
The cable that waedi has linked will work, I confirm.
But why you insist on avoiding the BNC-RCA adapter? Use the 75 Ohm one, it also works like a charm (I confirm this, too) and costs around €1.
5 (edited by ramses 2024-10-19 21:43:41)
Do you mean me? What do you mean with *insist*?
You seem to understand or interpret my proposal wrong. Language problem?
I simply "suggest" the alternative solution to let the ADI-2/4 Pro do the D/A conversion, as it supports even 5 different ref levels. The Neumann sub has nothing comparable.
I was referring to the OP who said explicitly they want to avoid an adapter. In fact, you posted while I was still typing, therefore I had not even seen your post then, so excuse me for this little misunderstanding wink
And now I even doubt which kind of adapter they meant. Perhaps the question is about the digital breakout cable. In this case, I am not aware of any cable that plugs directly into the DB-9 digital I/O port on the ADI and has a BNC connector on the other end, not to mention one that is long enough to be directly connected to the sub.
Thanks for clarifying :-)
8 (edited by KaiS 2024-10-20 08:14:44)
unpluggged wrote:
… And now I even doubt which kind of adapter they meant. Perhaps the question is about the digital breakout cable. In this case, I am not aware of any cable that plugs directly into the DB-9 digital I/O port on the ADI and has a BNC connector on the other end, not to mention one that is long enough to be directly connected to the sub.
In this case someone has to take a soldering iron and make a 75 Ohm DB-9 to BNC cable.
This is no rocket science, the DB-9 pinout is documented in the manual.
I did the same with an RCA to uncased DB-9 as the space behind my ADI-2 Pro was too limited for the breakout cable.
Took a few minutes to do so.
