Topic: UCXII in Class Compliant mode connected to MPC Live 2
I am trying to use my UCXII, in class compliant mode, as an audio interface for my MPC Live 2.
This configuration usually runs ok for about 10 minutes, before it starts to produce some "pitchy glitches", it kind of sounds like if the sample rate changes for half a secon, intermittently.
The sound that is monitored directly on the UCXII is not affected, only sound that flows through the MPC has this issue.
Now, I have gone through most of the settings of the UCXII as well as the MPC's settings, but I can't find a way to make this setup function in an acceptable manner.
Is there anyway that uses the UCXII for the same purpose without issues? Are there any tips that might be worth looking into?
Any advice would be very mcuh appreciated.
