Topic: Control DAW input configuration when changing sample rate
Good day everyone,
I'm currenlty running a UFX+ connected to ADAT (Cranborne 500ADAT) and MADI (12MIC and Pulse 16) units.
I was wondering if there's is a posibility to maintain the 1st MADI channel visible in the same position to DAW input configuration when changing the sample rates.
This appears to be required due to ADAT channels being inserted in TotalMIX layout between native UFX+ channels and MADI channels. (ADAT channels vanish/halved when sample rate changes say from single to double speed)
Is there a way to hide 8 ADAT channels or change order of ADAT being inserted after MADI in TotalMIX?
This would prevent me from having to swap DAW input configuration files back and forth when changing sample rates to maintain my naming convention of each input.
Example:
at 48k: first MADI channel visible to DAW is 31
- 14 UFX+ native channels
- 16 ADAT
- 64 MADI
at 96k: first MADI channel visible to DAW changed to 23
- 14 UFX+ native channels remain
- 8 ADAT due to using double speed
- 32 MADI channels
