Topic: Room EQ vs Loopback bug? Recorded audio passes through Room EQ
Hello everyone!
Happy UCX II user here but I just found out an issue with Room EQ and the Loopback function on the Main output.
Basically I usually use the loopback function to be able to record my screen and main audio output at the same time.
The problem is that the resulting audio will record also the Room EQ.
This means that the recorded audio, once played back will sound as if it was processed two times by the EQ: 1) inside the audio, 2) because the audio is going again through the Main output which has the Room EQ enabled.
Is there anything I can do to solve this issue or is this a bug/malfunction?
Really hope there's a solution to this. Ideally the Room EQ should be post-loopback, right?
Anyway, thanks for your help
DM
