[ Edited after reading the response in #6: it turned out, that all questions were related to UCX II ]
bsigvert wrote:The reason I'm asking is because I want to use the ADAT I/O for other tasks, such as expanding my I/O in the future,
but if I have to use the ADAT for the ADI-2 Dac fs out i loose this possibility.
And can I use the ADAT I/O independently from the coaxial spdif also?
Manual ch 21.3: you can use UCX II's digital I/O ports (AES, ADAT - switchable to optical SPDIF-, coax. SPDIF)
independent of each other.
Which means
- that all channels can carry a different audio signal and
- in terms of TM FX and routing: each digital output can have an individual submix like any other output.
bsigvert wrote:Does anybody know which cables are ins and which ones are outs in the breakout cable?
SPDIF is a 2ch protocol, indeed you only need one SPDIF cable. So you have a 50 percent chance of getting it right first time.
If it doesn't work, well, then simply try the other plug of the breakout cable, it won't break anything.
According to another product's manual (HDSPe 9632) red is output, ch 6.1. I would assume that RME uses this schema for all products, should be documented in the UCX II manual, although it's effortless to find it out yourself.
Recommendation: you should read your manuals a little to learn about your device's capabilities. They are real gems. At least browse through the manuals, they are well-structured. Then you learn about the structure and what information you can expect from it.
