Topic: connecting the RME as a headphone amplifier to the UAD Apollo x6
Hi there,
I am completely new on this subject that you need a headphone amplifier but I wanted to get the HEDDphone two for music mixing and mastering purposes. So I bough the RME Adi2 DAC fs and trying to make it work, but I did connect with the digital toslink cable and also the usn cable but no signal whatshowever... downloaded the remote but that didn't help. Anybody here in this forum with some usefull tips to have this set up/install this the right way to make it work? thanks in advance! Pirke
2 (edited by KaiS 2024-11-21 00:47:54)
Re: connecting the RME as a headphone amplifier to the UAD Apollo x6
To avoid any mis-configuration, start with a full factory reset, ADI-2 DAC in default will work:
• While powering up, push and hold the VOL button (NOT the VOLUME dial) and Encoder 1 and Encoder 2, until you see the message: “Reset done“.
• Make sure the latest firmware is installed, on power up V.62 is displayed (at the time of writing).
• ADI-2 DAC will read ADAT, but only channels 1+2 of a non-S-Mux signal.
So max. sample rate is 48 kHz, and UAD routing must be set accordingly.
• So, better use UAD’s Coax SPDIF out, which has no limits, or set the used ADAT/Optical to SPDIF format in UAD’s settings, if this option exists.
• Don’t mix ins and outs: UAD out goes to ADI-2 in.
• For the moment, leave USB unplugged.
In factory default’s Auto-Input mode USB would dominate the Optical/Coax.
Once up and running you can plug USB and change the input setting.
Hi there,
thanks for replying and taking the time to help out. Much appreciated! For other people with the same issue... here is what I did:
I did the reset: check . still nothing happened... update version V62: check... still no signal ... I dived into the UAD Apollo console app and did some trial & error. changed the bitrate from 44.1 to 48  and clicked on the Cue Outputs in the Monitor Control section and there I saw the option 'mirror to output' and switched that to the ADAT 1-2 : MAGIC!  all good and working now perfectly. thanks again
Great!
So it was indeed the UAD routing, like mentioned in my checklist.
Keep in mind that 48 kHz will be the highest sample rate for ADAT in this configuration.
Consider setting UAD’s ADAT out to SPDIF, if you happen to have higher SR demands.
