7enderbender wrote:Now I’m sitting here trying to
A) reset everything to factory default
B) understand what to do with the “snapshots” (it seems they don’t auto save settings, so if you change something and switch to a different “snapshots” you lose everything)
C) understand why “analog 1 and 2” don’t show up in hardware output bottom row
D) understand why I’m expected to route the reverb and echo effects to a loop back on an “unused channel” (what if I use them all?)
E) set up a basic “mix” that I hopefully never have to touch again that covers all
F) In and outputs and routes to the corresponding channels in Logic Pro X - while avoiding the “DAW mode” (which we have established isn’t really working for using the UCX2 for low latency recording that doesn’t use the software monitoring in Logic.
G) -or why the TotalMix FX window doesn’t fit the screen of my MacBook Pro when set to 100%. Information at the bottom is cut off and there is no way to adjust the window size manually….
H) I will figure this all out eventually - but I’m at a point where I feel like I need a class or hire somebody to sit with me for a few hours. And again, I’m usually not all that dumb.
to A) those reset options are very useful to start over.
This blog article which I wrote not long ago, gives you a good overview how to backup and restore. Additionally some tips, how to recover a workspace quickly using quick workspace select slots and using key combinations ALT-1..9.
I use it all the time successfully to be able to try something for RME customers on the forum and to recover in a second.
https://www.tonstudio-forum.de/blog/ent … nd-backup/
to B) Why should the snapshots autosave? The intention is that you can store and quickly recover a setup/routing for certain use case completely. If snapshots would be auto-updated/saved when they would modify and you would never be able to come back to a defined state for a specific use case.
To put an example, I am using 8 Snapshots for those basic use cases that I have
- Snapshot 1: Monitors - Monitoring through active monitors (via ADI-2 Pro FS R BE in "Recording corner")
- Snapshot 2: HiFi - Monitoring through (high end) HiFi (via ADI-2 Pro FS R BE #2 in "HiFi corner")
- Snapshot 3: PCM81 -14 - Using Lexicon PCM 81 as external FX for my Marshall Amps (using UFX III as parallel effect loop)
- Snapshot 4: PCM81 -18 - the same but litttle lower FX level
- Snapshot 5: PCM91 -13 - the same but with PCM 91 which I use otherwise more for the DAW
- Snapshot 6: Reamping - pluggin guitar into UFX III Inst input to record the "raw" guitar signal to playback through amp for reamping purposes with different amp gain/tone and different FX settings (PCM 81)
- Snapshot 7: PCM4DAW - change routing so that both Lexicon PCM (81 and 91) can be used in DAW as external FX
- Snapshot 8: S-Gear3 - routing to play through Amp VSTi and adding FX from PCM81
I only need to push one of the 8 knobs in TM FX or on the ARC USB, and then I can immediately perform with perfectly fitting routing and settings. Also in terms of monitoring while playing guitar to a backing track. All volume levels are optimized so that it sounds in the headphones like a real recording, but the guitar a little bit louder, which supports the playing.
If you change something on the recording interface and reboot the PC, then the last setting is remembered.
There is a last.* settings file, see my blog article which gets always updated if you either quit TM FX as applicaiton or if you reload the computer.
Of course, if you recall a snapshot or workspace .. then you get exactly those settings .. with good intention, see my 8 use cases / prepared snapshots above.
This functionality / workflow is really excellent and can be further expanded by providing multiple workspaces.
By saving/restoring either the workspace (including all settings) to/from your Apple computer.
Or alternatively, by using 30 Workspace select slots which have 8 Snapshots each (in total 240 snapshots).
And as you can recall the first 9 workspaces out of 30, then you have 9*8 = 72 Snapshots "at your fingertips".
Because you can restore them by using key combination ALT-1 .. ALT-9.
Isn't that great ? ;-) You will learn it .. give it some time.
to C)
Because you seem to have moved it into the TM FX control room (see bottom right).
This happens if you assign HW outputs to certain predefined "roles/functions" like Monitor A, Monitor B, Phone 1 .. 4 etc.
The reason to move those ports to the control room is, to get the typical control room functions for your monitoring.
Like mono, mute, etc ....
For active monitors, headphones this makes sense, for connected FX not really ...
So you use the Assign button and assign the devices for monitors to those roles.
And then they appear in the control room so that you can use control room function in TM FX or via the ARC USB remote control unit.
to D), sorry I do not get the point. To what part of the manual (is it from manual) do you refer. Please tell the source of the information or your use case why you want to use this.
Be informed upfront, that the FX are useful for example to give a vocalist a little reverb, without its monitoring having to go go the longer way over the DAW to use DAW reverb and for similar things.
But you only have one FX settings and in each channel you can determine the amount of FX level.
If you need more flexibility and individual settings for each channel -> DAW.
to E) maybe have a look at may step by step primer which I already mentioned in the sticky forum post of subforum.
I gave you the link already. I understand, that it is difficult to "digest" all information at once, maybe you didn't have
time yet to look at it, see here: https://www.tonstudio-forum.de/blog/Ent … rnal-equi/
Basically .. assumed you route everything in the DAW to one stereo sum.
What do you need for monitoring / what use cases do you have?
Well .. to route Audio from Apple / from DAW to either active monitors or headphones.
To break that up in steps
1. assign your HW output where you connected active monitors using assign button to "main out"
by this you see this output channel in the control room
2. assign your HW output where you connected headphones also using assign button to "Phones 1"
3. check that you are in TM FX Mixer view (M) and in Submix mode (see upper right, blue area)
4. Select Active monitors in the control room (click with left mouse button)
Now you see according to fader position the submix / the input and sw playback channels that send audio to this particular output, therefore you see the channel name at the base of each fader at top and middle row.
Turn down all fader in top and middle row.
Only raise the fader to 0 dB from the middle row (SW playbacks) to hear audio from the PC.
This will usually be the first pair of (stereo) channels AN1/2. If you play music you can see it according to metering activity.
But you might send in DAW or other application audio to a different channel, then it is one of the other channels of middle row.
This is the patchbay character, in TM FX you determine finally on which output you want to listen the submix of "this and that" input or sw playback channel.
5. Store the routing in Snapshot 1 as "Main Out" or whatever you prefer
6. Store the workplace as backup of this to your PC (it contains window position, routing, snapshots, ...
Everything but certain more generic TM FX settings see my blog article about backup and restore of settings
7. As an option save this also to Workspace Quick select slot 1, to be able to recall exactly this settings at any time with
the key combination ALT-1
Well now the same for routing to headphones, select the other HW output (in the control room), phones 1.
And then also create proper routing, as you like, see template steps above, then store the settings
(backup to workspace and update your Quick Workspace Select Slot).
to F) DAW is only for people who want to do everything in the DAW and do not care much about latency.
You can get the same routing as DAW mode in TotalMix FX full mode.
This has been explained a few times in the forum.
In TM FX click: Options -> Reset Mix -> straight playback.
Then you have DAW mode pluse the flexibility to add some additionally needed stuff to avoid latency for some flows, e.g. for monitoring.
There is a variant which routes additionally audio from PC (middle row) to "Main Out", where your monitors are connected.
Might be useful as well ...
to G)
TM FX uses Bitmaps, not vector graphics. In the old days PC and GPUs were not so powerful.
Using Bitmaps is faster and lag free (other vendors do not care so much about this level of quality).
It also provides best backward compatibility to older simpler GPUs which are often being used for DAW setups.
We saw it now that the new DIGIcheck NG (using more modern graphic) didn't run on older more limited GPU cards.
So the intention here is speed, lagfree and to support best backward compatibility to older HW which is still in use.
A "quick" rewrite of TotalMix FX is not possible, its would create massive amount of work as RME already explained in the forum.
What you can so is to use the fix resizings, for those Bitmaps had to be created, also a time consuming process.
Sorry, no other / better news about this.
Some people use TM FX 2-column mode of the window is too tall (in the y-axis). Check out 2-column mode,
then the top and middle row are collapsed into one top row.
In the bottom HW outputs and the Control room.
You find it as button "2ROW" (a toggle) on the upper right in the blue area.
to H) I am sure you will like it and get used to it.
Simply give it some time, its completely natural that such things need some time to settle.
Also Rome has not been built in a few days.
Your main problem is maybe expectation how you think it should work for you personally and based on your experience (be it good or bad) with other vendors.
Please be patient and stay open minded, RME has the best concept here.
As I and some other gents from forum mentioned, you need to know only a few things .. some little basic concepts of TM FX.
Once understood you will never want to go back to something different.
I also came from Focusrite ...
If you are in the mood, look at my setup here, even if it is already quite complex for a guitarist.
https://www.tonstudio-forum.de/blog/ent … iii-en-de/
With TM FX I have everything under control and feel confident and am excited how easy it is finally to work with FM FX.
Otherwise I could not build something like this in my spare time. Music is only my hobby.
And here the documentation of it:
https://www.tonstudio-forum.de/blog/ent … tup-en-de/
Here the evolution of my setup (little older state with UFX+ and amp mono setup, I have now a stereo setup with two marshall combos, because the Lexicon PCMs are stereo units (without mono presets, or only very few):
https://www.tonstudio-forum.de/blog/Ent … -DURec-DE/
