1
Topic: DigiCheck NG 0.92 beta 2 – public preview Mac /Windows
While busy with many projects we still found the time to work a bit on DigiCheck NG, and added a feature often asked for: VU meters!
https://www.archiv.rme-audio.de/images/program_meters.jpg
Now, these are a bit two-sided. They either are just seen as nice-to-look-at toy, or as useful addition to the measurement arsenal already at hand. And if you are younger you might not even know what these swinging needles are good for at all. They had been radio and TV standard for a long time, but yes, both their technical definitions on working as well as the mechanical design are both outdated and/or obsolete. Nevertheless, here they are to try out and learn some interesting stuff!
https://www.archiv.rme-audio.de/images/qpeak_settings.jpg
Select the new Instrument type Program meters. Several VU meters show up. Click the right mouse button to open Settings, then select
- the kind of VU meter, Meter Type. Choices are Volume Unit (300 ms attack/release) or Quasi Peak (also Peak Programme Meter, 10 ms attack, 1.5 s release for 20 dB, different scale).
- Channel count for the number of meters
- Line Count for the number of vertically stacked ones. For example for a 24 channel tape machine setup you can have 12 in 2 lines, or 8 in three. Or with only 4 meters stack them all vertically at the edge of the monitor in 4 lines – whatever you want.
- Reference level lets you set the 0 dB point lower, for higher sensitivity. This is un-avoidable with the VU meter as you will quickly notice – with normal material that reaches 0 dBFS the needle hardly starts to move away from the -20 dB end of scale. The Quasi Peak meter acts much more like a typical digital level meter, and usually does not need that workaround.
- Motion Blur is a technique to make the needle swing smoothly instead of stuttering, even at 60 Hz frame rate.
- The optional Peak indicator reminds you of the true level the measured signal has. Especially with the VU meter the difference between peak and heavily averaged (the needle) is mostly very big.
- The levels for yellow and red color of the peak indicator are freely adjustable.
Note that the Windows version comes with installer to provide the included help. On Mac it is included in the app itself, so no installer for now. The included help describes the new Program Meters in more technical details.
We hope you like this stuff, and appreciate any feedback.
Downloads - Updated with link to release version
Windows: https://www.rme-audio.de/downloads/digi … in_092.zip
Mac: https://www.rme-audio.de/downloads/digi … ac_092.zip
Further info:
https://en.wikipedia.org/wiki/VU_meter
https://en.wikipedia.org/wiki/Peak_programme_meter
2 (edited by waedi 2024-12-12 12:48:35)
Re: DigiCheck NG 0.92 beta 2 – public preview Mac /Windows
It looks great !
Thanks for this new feature
Tested with Digiface USB on M1 Mac, works fine.
Thanks for the continued development on Digicheck NG, I'll try them against my Sifam hardware meters!
https://musicwall.app/hermetech
Fantastic! Appreciate the update..
Old skool VU’s are still a big part of my metering arsenal!
Si
Very nice!
Amazing, how perfectly the mass/rise time of the needle in the VU meter is "emulated".
Really useful. Thanks.
“Do It For Her”
6 (edited by Dmitry67 2024-12-13 15:02:16)
Hello!
Nice job!
Need an option "Always  on top" like in the old version DIGI.
Thank you!
Thanks, MC, nice job!
I like the new VU meters. Nice. They are working as expected on my M2 Pro Macbook Pro running Sonoma 14.5.
Unrelated issue. The 2 channel level meters take up too much vertical space when in horizontal mode. The borders on the top and bottom of the window can hot be hidden or made smaller. It would be an improvement for my use case to have the horizontal channel meter window only show the meters and hide the title bar and gray space aboe and below the meters.
Is this not available on fireface 802?
It is available as standalone software with own download link, see above and it should work with every RME interface...
The VU meters don't seem to let me choose playback channels as inputs on my DigiFace USB. Is that intentional?
These VU meters are fantastic MC.
13
Isn't it true that none instruments do so?
Yeah, they are really good, perhaps the best digital VUs I have seen (have tried lots!) They measure very closely against my hardware Sifam VU meters when calibrated the same. Look great full screen too!
Is there an option to set VUs only for two output channels? I don't need the whole channel-set and it takes quite a bit of real estate in Digicheck.
16 (edited by waedi 2024-12-16 17:19:14)
See post 1 the second image with the settings
channel count number and line count number, may be this is what you are looking for ?
Thx! Didn't read that properly. Very nice, thx RME! Now I wish to have more than four instrument panels big_smile
Thanks for the update. I like the old VU meters! Will definitely check them out.
Would it be too much to ask to implement them into the ADI-2 series screen?
One channel (L or R, or L+R) full screen, please.
What would be super helpful for me would be to have the Reference Level setting as a knob/control on the VU front panel itself (maybe switchable on or off in the settings, like the channel names?) It's something one needs to change a lot when listening to different types of music, and at the moment is a little frustrating to have to go into the settings every time to change it.
All other meters in DigiCheck NG work with the playback channels (but only when using the DK driver).
21
Unfortunately your issue descriptions are not much helpful. What exactly is the problem here? Too low level so needles don't move? KE driver in use which doesn'' support playback in DC NG? You did not select the right channels in the Input Selection dialog's table? A more detailed description with screenshot might help.
Assuming this is a rely to me:
Unfortunately your issue descriptions are not much helpful. What exactlky is the problem here? Too low level so needles don't move? KE driver in use which doesn'' support playback in DC NG? You did not select the right channels in the Input Selection dialog's table? A more detailed description with screenshot might help.
Like I said, the VU meters don't let me choose playback channels as inputs. I'd love to attach screenshots, but can't figure out how.
I'll try to describe what I'm seeing: in the "Program Meters Inputs" dialog box I can select input channels for up to 8 meters via dropdown. The dropdown lists offer channels ADAT 1 to ADAT 32, nothing else. With other instrument types I get ADAT 1-32, Playback ADAT 1-32, Playback Phones L and R. The "Add Playback Channels" option under "Setup..." is checked, btw.
Just playing around with it a bit I notice that other instrument types (like Totalyzer) also sometimes don't offer channels beyond ADAT 1-32. I never had that issue before. I can recover from that by loading a saved layout, then the playback channels are back. So perhaps this is just a UI issue with populating the dropdown. I'll keep messing with it, perhaps I'll eventually get the full dropdown for the Program Meter inputs by chance.
I think I found a workaround: When creating a new window and adding a new instrument, don't make that instrument a "Program Meter". Instead, choose a different instrument type, configure playback channels as inputs, then change the instrument type to "Program Meters". The playback channels will prevail.
Not sure how repeatable this ultimately is, but it has allowed me to share the joy of the VU meters
24
Thanks for these details. We'll check and will fix in case we find the issue.
Thanks MC! Loving the update. Getting close to retiring my Clarity-M I think.
The VU meters are fantastic!! Thank you!!
Windows 11 / Nuendo 14 / HDSPe MADI FX / M-1610 Pro / ADI-2 Pro FS R
Thanks a lot for this great realisation!!! We are spoiled, it looks really great smile
28 (edited by waedi 2024-12-23 20:32:39)
menu File / New window
Open some more Digicheck windows as much instruments as you want.
Sehr geehrte Damen und Herren,
ich benötige bitte Unterstützung bezüglich Digicheck NG. Ich habe die Software auf meinem Computer installiert, und alles hat einwandfrei funktioniert. Am nächsten Tag jedoch, als ich die App öffnen wollte, erschien sie zwar in der Taskleiste, aber das Programmfenster wurde nicht angezeigt.
Woran könnte das Problem liegen?
Die ältere Version von Digicheck ist ebenfalls auf meinem Computer installiert und funktioniert problemlos.
Vielen Dank im Voraus für Ihre Unterstützung.
Mit freundlichen Grüßen
Nelson Wandji Okafor
30 (edited by ramses 2024-12-30 13:10:15)
Dann benenne doch einfach mal die Datei, die den "last state" der Applikation enthält, um.
Das wäre doch das Naheliegendste, um für die Applikation für den Start wieder Default Werte hinzubekommen.
Das sollte solche Startprobleme lösen.
Vielleicht ist das Applikationsfenster versehentlich auf einem anderen (nicht mehr angeschlossenen) Bildschirm gelandet
oder irgendeine Fenster resize Aktion hat die Fenstergröße versehentlich auf "0" schrumpfen lassen. Dann sollte allerdings noch die Titelzeile des Fensters sichtbar sein. Nun .. wer weiß .. einfach mal ausprobieren.
- Applikation (DC NG) schließen
- Ordner C:\Users\<loginname>\AppData\Local\DigiCheckNG im "File Explorer" öffnen
- Datei "lastState.Analyser.xml" umbenennen in "lastState.Analyser.xml.old"
- Applikation neu starten
Und - der Vollständigkeit halber - bitte OS Version, Grafikkarte und Treiberversion angeben, falls die Info noch gebraucht würde.
Dabei bitte konkrete Versionsnummern angeben, der Eindeutigkeit halber, nicht "letzter Treiber", danke.
Is there a possibility to open two instances of DigiCheck. Like if i would like the VU meter and vector audioscope only? Cant really find a way to have more then one instance at a time.
^^ Yes. Open "File" menu and select "New Window" from drop down. You can then assign "Instrument Layout" as required from "Options" menu .
Brilliant! Thank you! big_smile
34
Version 0.92 is now released for Mac and Windows (updated link in first post). Compared to the beta there are a few further improvements:
- Optimized automatic placement of Program Meters
- Saving and restore of fullscreen mode on second monitor
- Smoother release of peak bars in 2 channel meter
- Only Mac: slightly reduced CPU load when using multiple instruments
35 (edited by DominicPerry 2025-01-09 16:27:52)
This latest version (0.92) creates a zip file on my local drive that won't unzip and won't delete.
It may be specific to my machine, but I haven't seen this before, so just reporting here in case anyone else sees the same bahaviour.
MacOS (Ventura 13.7.2)
Dominic
.zip worked fine and 0.92 installed fine here (Win 11). Thanks for the update.
37 (edited by Rob Sinistral 2025-01-11 13:25:25)
I found out about the release via a post on from the RME Facebook social media channel.
I followed the instructions in the post and found that Digicheck NG release was not available via the download link, so I asked in the comments whether this release was compatible with FF800.
I thought it best to report this issue here, as I tried also to download for FF802 also (as a test).. and saw that the link to Digicheck NG was also missing for this device. I have since followed the download link via the forum and installed and used it successfully. I have to say, it is awesome work... many thanks for this. smile I love you guys!
Best Regards
Rob
Here's a link to that post: https://www.facebook.com/RMEAudioOffici … gZYSOozVzd
38 (edited by grada 2025-01-12 02:33:20)
Totally replaced old Digicheck with NG since the begining and I love it! One thing i noticed on v092 that is hard on eyes. Especially on mini monitors screens 1080p looks even worse that are dedicated for analyzers section. What others think?
Is there any technical reason for the change Matthias?
Full res picture here: https://i.imgur.com/Z8JFpxP.png
39
You try the impossible: too many pixels squashed into less existing pixels - results in aliasing. If you reduce the window size that much change the settings to less dB per LED.
It is.
Reading problem. The facebook page clearly told you to select Software (dropdown list on the right), not to look for drivers. DC is no driver and not listed under drivers for ANY interface.
41 (edited by grada 2025-01-12 17:02:26)
Thanks on replay M really appreciate your input.
However i cannot agree with you on this one and please let me be constructive as much as i can (unless i am mistaking on some settings or something)
Tested without any system scaling on my Ultrawide 34" IPS monitor as well on my reference OLED Samsung 77" S90C. The 091 is much better on eyes with less fatigue.
Here is direct comparation. Full res pic: https://i.imgur.com/ohUDmCO.png with pretty much big digicheck win size (~1400x800px)
On closer inspection i noticed that v092 has some additional shade lines that making "blur" effect. Full res pic: https://i.imgur.com/5k1UUUb.png
I do agree to some extend that on bigger screen 092 is more tolerable than on smaller screen but side by side 091 is much more pleasant on any screen. In my case 092 is unusable on my little monitor (16" Full HD) dedicated for analyzers (look how sexy it is https://i.imgur.com/ikiUNdh.jpeg)
Please find this feedback constructive as much smile
IMHO v092 is better than v091 when looking at your screenshots.
And yes, adding grey lines on border between too dark and too light makes readibility much better. It is a common "trick" how to improve readibility. It is used mainly in designing icons, but IMHO it has its place also in heavy grids like this one.
But the perception, what is better and what is worse may depend on eyesight, monitor used, resolution, and so on...
43 (edited by grada 2025-01-12 19:34:12)
https://i.imgur.com/qTPFt77.png
really the one on the right is easier on the eyes for you? Quite interesting since for my eyes it gives me nausea cause of blurriness, the one on the left is much more pleasing.
I don't mind getting grid bolder as similar with old digicheck, but for my eyes something is a bit off. What others say?
44
The down-scaled comparison shown here in the forum is misleading. Checking the pic from your link (full size) indeed the lower one (v92) looks clean, while the upper one (v91) shows aliasing artefacts. It turned out that v92 includes a small fix as the anti-alising engine, necessary for the free-scaling functionality, did not work perfectly before. Now it does.
In most cases the difference is either very small or not noticable at all. It really depends on how dB/LED is set, the size of the window, and whether your monitor is HD or better.
45 (edited by grada 2025-01-13 14:12:34)
Rectangles with perfectly horizontal and vertical lines(no roundings) what we have here does not typically need an anti-aliasing filter or not this much as I point here: https://i.imgur.com/5k1UUUb.png . Because the edges of the rectangle align perfectly with the pixel grid, so there are no partial pixels or jagged edges to smooth out. It has more sense for diagonal or curved lines where pixels don't align perfectly with the edges, resulting in a jagged or "stair-step" appearance.
Being said that it simply cannot looks more "clean" adding sub-pixel blends/intermediate pixels (also visible in link above) to the perfectly straight lines, on the contrary it looks more blurred and less sharp.
Saying that is "necessary for the free-scaling functionality" is perfectly valid argument for me. And totally understand if that has to be implemented for better usability in trade for more sharpness.
Just think of it as a simulation of old-school LEDs. :-)
Hi Matthias,
Indeed! smile It did tell me to do that, but when I visited the website: I automatically chose the device instinctively, then didn't see the software option, as when you select the device, the software option dropdown disappears!
The labelling beneath the dropdown box selection didn't catch my attention due to to the vertical visual hierarchy. Upon further inspection however, I see how it works!
Had it been labelled in a way that is very clear, with optimal vertical visual hierarchy I would have picked it up straight away on the website. I sketched something that would have helped me with this in the image linked below.
Many Thanks for this update. I think maybe the old generation digicheck is finally seeing less action!
Best Regards
Rob
https://ibb.co/RC8CLYF
48 (edited by ignaceland 2025-01-23 14:28:29)
Hello RME, this is great.
I am testing on a Windows 10 system with a 1366x768px resolution and I am not able to see the Channel names/numbers from my HDSP9652 correctly.
It looks like it tries to display their full name which starts with HDSP9652 AD... but it doesn't have enough space to write it all, so all channels are named the same.
I tried zooming out as much as I can. The same happens with a 2-channel vu-meter instrument.
May it be possible to change the names or do something about this?
https://i.ibb.co/xSsNjSX/digicheck-vu.png
49
Go to right click Appearance, then change the Font Size Label to a lower number to make the font below the VU meter smaller.
Better naming options are on our list but will take some time.
Hi Matthias, thanks for the response.
Unfortunately doing so only lowers the font size but doesn't add more characters:
https://i.ibb.co/s9JjdyR/digicheck-vu-font8.png
