Please Help, lots of trouble with latest DK (4.17) and KExt (3.33) drivers
Hi, I'm running on a MacBook Pro (16", 2019) on Big Sur 11.7.10, using a Fireface UCX connected (directly to the MBP, not through hub) in USB, with nothing else on it but a 48v-powered mike and a guitar. UCX outs are directly connected to my studio monitors.
So far I was running quite fine w/ a firmware update that was dating back in 2019 (installed w/ RME USB Series Flash Tool v1.68) and with the Kernel Extension driver v3.19.
Today I:
- First, upgraded the firmware to v49
- Then, tried to install DriverKit v4.17 - which based on install "Read me", is supposed to uninstall existing former K. Ext. (see issues I encountered below)
- Then, tried to install K. Ext. v3.33 - which based on install "Read me", is supposed to uninstall the DriverKit extension (see issues I encountered below)
- Then, tried again several times to re-install either of them on top of my system (running the Fireface USB DK 417.pkg or the Fireface USB 333.pkg file), which switches what driver Fireface USB Settings is reporting when I launch it.
At each stage, the Fireface USB Settings app was reporting the correct version of firmware (49) and of driver (either 4.17 or 3.33). Besides, TotalMix FX was updated to 1.97 upon the very first driver install above.
I get the following issues.
For the first couple of minutes after reboot, all seems file, though the MBP fans run fairly hard upon startup and after.
After 2-3 minutes issues pile up.
Common to DK 4.17 and K.Ext. 3.33
- Total Mix FX starts blinking slightly, as if display of its window was slightly unstable
- Sound out cuts suddenly, and audio out switches to another hardware
- All the system (inclus Finder, system prefs), Apps (all open ones), reaction time to mouse or keyboard actions, gets very sluggish (maybe a little less so with DK 4.17 but still quite, and definitely extremely sluggish w/ KExt 3.33)
- In my DAW (Logic Pro X 10.4.8) audio in gets chopped (sounds like a lot of jitter)
Specific to DK 4.17
- In system prefs/sound, Sound Out display of Fireface UCX stays stable, but in the Sound In pane, the Fireface UCX blinks in & out repeatedly, every few seconds
Specific to KExt 3.33
- In system prefs, when I try to access the Sound tab, I get "Preferences Error - Cannot load the Sound preferences window"
- In Logic, can't find any input but Input 1
Once I reach this point, the only way for me to get back to a useable computer (no sluggishness, at least), is to turn it off, disconnect the USB cord of the Fireface UCX, and restart. In other words, my Fireface UCX is now totally useless and I cannot work in my music studio since I no longer have an audio interface up and running.
MY MOST URGENT NEED:
- How can I uninstall both DK 4.17 and all RME KExt that might sit on my system, as well as TotalMix FX, and install back my former KExt driver and version of TotalMix FX which were working just fine (I still have the 2019 install package on my hard drive) ?
Nice to have, but less urgent:
- What should I do to solve the above and run either of the most-up-to-date of DK or KExt driver + version of TotalMix FX flawlessly?
Thanks in advance for your help.
Cheers,
Arnaud
