201 (edited by DanRand 2024-06-13 09:58:51)
Re: New macOS RME HDSPe series driver – public beta test (1.07)
Hi !
Just tried to install 1.07 & then 1.12 for my Digiface + ExpressCard (with Sonnet adapter), but the HDSPe Settings app immediately closes for both firmware versions, and the Digiface doesn't show up in Audio MIDI Setup, TotalMix or HALLab, or any audio apps.
Any idea how to fix this or what the cause might be?  I see others in this thread have also mentioned the settings app not opening.  Kernel driver 4.25 works fine.
Thanks.
Some details:
macOS Monterey 12.7.5, intel iMac 9900K
Firmware v21 (DriverKit Compat.) - Was updated with FUT 3.14
IORegistryExplorer shows 2 IOUserServer entries, and a PCI... entry
SIP Disabled
I also have a UFX III and UCX I which are working fine with their ASP + DriverKit driver
Can send Console logs that happen when HDSPe Settings app immediately closes
Logic 10.7.2 - macOS Monterey 12.7.5
HDSPe Digiface via ExpressCard Adapter
Fireface UFX III & UCX I
202 (edited by DanRand 2024-06-13 10:26:37)
Forgot to say that if I type "systemextensionsctl list" in Terminal, the following lines for the Digiface are displayed:
de.rme-audio.dkhdspe (1.1.2/12)    de.rme-audio.dkhdspe    [terminated waiting to uninstall on reboot]
de.rme-audio.dkhdspe (1.1.2/12)    de.rme-audio.dkhdspe    [activated enabled]
And there are 2 corresponding folders/entries containing a "de.rme-audio.dkhdspe.dext" file in /Library/SystemExtensions
Also, there is an "RMEHDSPeAsp.driver" driver showing in /Library/Audio/Plug-Ins/HAL
Could you help me?
I did the firmware update and now my HDSPe MADI FX card is no longer recognized by my Mac Pro which is on OSX 10.14 (Mojave).
What should I do to make the card accessible again by my Mac Pro? I tried to reinstall the 1.28 driver but nothing happens.
Thanks in advance
204
Current DriverKit version is 1.13. 1.28 is an outdated KE driver that won't work with a DriverKit firmware. The latest 1.34 would do so, but as it is KE it requires to reduce system security, so better use 1.13.
