Topic: Madi FX Plus in combination with 2x Ferrofish A32 Pro
Greetings,
I currently own:
MADI FX Plus
Everything syncs and works absolutely fine. However, the first madi port is for channels 1 - 64 and the second madi port is for channels 65 - 96. I am using the Ferrofish A32 Pro as a 32 AD/DA converter. Every time I want to set my outputs or inputs (in Reaper or Total Mix) I have this huge empty gap of channels that are of no use to me (channels 33 - 64) that I have to scroll by to get to channels 65 - 96 on my 2nd Ferrofish Unit.
Is there a way to have both Ferrofish units on a single madi port of the RME FX Plus? Or is there a way to route or set this up?
Alternatively, is there a way to disable channels 33 - 64 so they do not show up in Total FX? Reaper does not allow me to select the individual inputs and outputs I want to use. They only allow one to select first input/output and a last input/output.
Any help or forwarding me to an appropriate thread would be appreciated.
Many thanks.
