Re: The official Babyface Pro Thread
Any chance for a low pass filter on the hardware outs of the babyface? Surely the dsp can support it.
RME User Forum → FireWire & USB series → The official Babyface Pro Thread
Surely there is no DSP.
Surely you jest. Is the DSP meter bar in totalmix decorative?
Doesn't even have to take up any additional resources. I mean, if it can have a high pass on every output, it shouldn't be that hard to give it an option for a low pass instead, right? Right?
I'd be more than happy with a configurable high or low cut per hardware out.
Surely as an owner of the BF Pro you should know it does not have DSP.
Wrong. The filters are implemented in the FPGA
Then you should look at interfaces that have DSP, such as the UCX II.
The Babyface Pro FS is an excellent device, but its design emphasises portability and operation via the USB bus. To achieve this, it does not include a DSP as this would increase power consumption beyond what the USB power supply can handle.
If you are looking for more advanced features, such as an integrated DSP for effects or advanced connectivity, upgrading to the UCX II would be a significant step forward. It offers a more robust feature set while maintaining exceptional audio quality.
For this reason, I often recommend considering a slightly larger model first. The Babyface Pro FS is characterised by being compact and versatile, but it's not designed to replicate the full feature set of its larger counterparts. By upgrading, you'll get a more future-proof setup and get even more useful functions, some of them from the flagship devices like Mic Preamp with 75 dB Gain, DURec, full implementation of DSP chip, RoomEQ and cross-feed.
Hence the name Babyface...
stej wrote:Surely you jest. Is the DSP meter bar in totalmix decorative?
You're coming off a bit hostile for no apparent reason.
No, as an owner of a BF pro fs for a few years now I did not know that it doesn't have a DSP. Nor do I think that I should have reasonably known. How should I? The manual mentions multiple times a DSP and there's a DSP FX meter in totalmix. I don't even think there's mention of FPGA anywhere in the manual. If there is, I haven't seen it and I've read it multiple times over the years.
Regardless, so this FPGA or whatever it is, is not programmable via firmware update?
As for the suggestion to use an entirely different product instead, that is not portable, please refrain from assuming. You know what they say.
Not any more hostile than you, mocking Matthias.
This does not speak in your favor.
This is what BF Pro's description says on the RME website: "The FPGA-based DSP mixer adds a flexible, 3-band parametric equalizer to all inputs and outputs."
Also by reading through this very thread (and just the very first post of it) one can learn that there is no dedicated signal processor and the DSP functions are implemented in the FPGA. At least I could figure this out.
It mentions DSP in context of signal processing; nowhere does it say that BF Pro has a dedicated fully-featured programmable digital signal processor.
TotalMix FX uses the same UI for all RME interfaces. Besides, this meter indicates how many FX are activated, not the actual DSP processor time usage. And it says in the manual that the indicator is only for information purposes.
It took me two seconds to find it, even though I don't own the BF: section 21.6, second paragraph
The Babyface Pro uses a DSP engine within its FPGA for all the calculations of all the EQs and
Low Cuts
Too bad.
FPGA has limited hardware resources and it is not as versatile and flexible as a software-driven DSP.
The BF Pro is more compact, but it is limited when used in standalone mode. So you need a DAW to be able to use all of its features. The UCX II, OTOH, is slightly bulkier, yes, but it can be used in fully standalone operation and is better suited for such scenarios due to having a display and six preconfigured setup slots. So it's a matter of a debate which of the two is more portable.
Yes it is, it a programmable field gate array. But it has very limited size and no ram, so might not be possible. Advantage, the dsp and ram can not break, cause they are not there.
Will negative values on the hi shelving filter not do the job?
I did no such thing. It was a light-hearted comment that you misinterpreted.
I have great appreciation for Matthias's constant presence in these forums.
Disregarding everything else as I'm not in the mood for forum bickering.
Well, they kinda do, but it's a bit janky.
Need it for crossovers and you know how it is. Can never get it quite right without high/low pass filters.
Or at least I can't. If anyone got an awesome recipe for doing crossovers with shelving filters I'm all ears.
Anyway, if it's programmable and it's possible to give the option of a high cut with a firmware upgrade, it would be a fantastic addition.
If you don't need the mid band both shelving an mid together get very close. First do it by eye so that it looks like a low pass. Then adjust freqs. just test on a track that needs it how close you get to a lowpass in your daw
Maybe it does not fit in FPGA, otherwise it would have been, IMHO, implemented from very beginning....
More correctly: It does not have DSP chip, while it has certain DSP calculations done by FPGA.
What I'm doing currently is 2 shelves on each output. All set to the crossover frequency, Q 0.8, +20/-20 gain.
And phase inverting one of the two outputs.
It's much steeper than a regular crossover, it won't completely fade out the rejected side and needs lowering faders by 20db to counter the +20 eq boosts, but eh, kinda works.
If I understood correctly your suggestion is to use a single higher Q shelf per output and use the mid band to take out the notch?
No just use the mid band to take out even more of what needs to be removed and/or make it steeper.
Of course I have no idea what you are practically doing, so my advice might be totally off.
Right. So a wide bell on the crossover frequency to make the slope steeper. It's on the same spirit of what I'm doing with the double shelves I suppose. I'll see if it can work since I'd really like to get rid of the positive gain shelves.
I've been experiencing full scale noise in my headphone output. It may be just one side (L), and it happens on computer restart. Windows 11, driver from October 17, 2024 (version does not appear in Fireface USB Settings window), HW rev. 206. I believe this has only been happening since the last driver. Muting the output in TMFX stops the sound from reaching the headphones, but the noise continues (don't remember the block diagram of the unit so I mention this). I have an ADAT unit hooked up and I'm running at 96kHz with a 256 sample buffer, as of the last incident. Toggling the EQ on the HP output off and on stops the noise. This has happened twice so far, and needless to say it's extremely unpleasant. A forum search turned up no matches for full scale noise or noise burst. Can anyone help me resolve this issue? Thanks.
EDIT: I see there are two or three other threads. Reading them now:
https://forum.rme-audio.de/viewtopic.php?id=40435
- Will try firmware 225.
https://forum.rme-audio.de/viewtopic.php?id=37598
- I see this is not resolved. Happening for HW 206, apparently (firmware).
https://forum.rme-audio.de/viewtopic.php?id=39519
- Different unit.
https://forum.rme-audio.de/viewtopic.php?pid=228228
Ok, I downgraded to HW203, but I'm currently too scared to turn the EQ on the headphone output. I'll be sure to post any changes. No noise on first restart.
EDIT: added another topic with the same problem.
Hi all,
I wish to expand my Babyface Pro FS over ADAT. I have a question that I suspect has a simple answer, but I can't answer it myself at the moment.
My question is about the possibility of clocking two external devices (an input device and a separate output device).
Would the master clock from the INPUT device be reliably passed through the Babyface to the OUTPUT device?
Would such an arrangement likely be stable?
This is what I want to do specifically:
Connect an Arturia X8 OUT, slaved to the Babyface. This will work with no issue at all.
Here is where I'm not as confident: in a few months, I would likely buy an input expander (eg Audient ASP800 or similar). This would by necessity be set as master, and the Babyface and X8 OUT as slaves. I can't tell from the manual if this will actually work.
Is this how it typically works with an AD/DA device (eg ADA8200)? As in, the two stages are usually separate anyway?
Thanks in advance for any info you might be able to provide. I've been an admirer of RME since the day I bought my old Fireface 802 (now sadly sold).
Yes to both, there should be no issue with this setup.
Thanks Jeff, much appreciated.
@Willo
Also, if Arturia X8 has WC out (or ADAT/SPDIF/AES out) and ADA8200 (or other AD) has corresponding clocking input (WC/ADAT/SPDIF/AES in), you could have Babyface as master and the other two as slaves. Clocking of ADA8200 would be delivered by Arturia X8.
BF<--- ADAT ----- ADA8200
| WC/ADAT/SPDIF/AES
|----- ADAT ----> Arturia X8
Hello.
My babyface pro fs have a new features.
1. Out 1/2 LED indicator is bilking when LED meter is overloaded and Red LEDs flashed.
2. Dont overload any channels showing in Total Mix when LED level meters is flashing.
What is this…Help
Hello.
What is this…Help
In the bottom of the unit is a switch for output level setting, try play with it.
Level switch is standart +4dBu level.
https://photos.app.goo.gl/Ns6RxdMiUxrgo3fg9
Video about this problem
@Kubrak
Thanks for the tip.
I had the same idea, but the Arturia only has ADAT and Wordclock in.
I contacted Arturia about my question about a month ago, they figured it would work, but suggested I check with RME to be sure. I tried to figure it out myself first before asking here!
Hello, people.
Around the same time, I installed the Roland Octa Capture device on my MabookPro M1 2020, and I updated to macOS 15.2. Everything was fine with 15.1.
I'm not sure what the cause was, but after that, there just doesn't seem to be any way to get my Babyface Pro FS recognised by the OS or any other software.
I have tried rebooting in recovery mode and running what is indicated here: https://rme-audio.de/rme-drivers-macos-reset.html. Then, I have reinstalled the drivers, trying both USB Series DriverKit Driver 4.17 and USB Series Kernel Extension Driver 3.33.
I wanted to try a Flash Update but the RME USB Series Flash Tool.app just won't open when clicking on it, and there is nothing in my Privacy settings that needs to be given permission.
Total mix won't open either, although it looks like the app is open on the toolbar. Fireface USB Settings app just won't open.
Thank you in advance for your help.
Dario
Your Babyface is seen in Audio MIDI Setup? Then it is in Class Compliant mode.
Hello, Matthias.
No, it is not seen in Audio MIDI Setup; it is not seen anywhere whatsoever.
Assuming that it being in Class Compliant mode is the problem, how can I change that from the hardware without having access to the software setup of the Babyface, as the app won't currently open?
Thanks,
Dario
Hello, again.
I switched it to CC mode and it was then recognised by Audio MIDI Setup and the other software, showing that the data type was integer instead of floating point. When I switched back to non-CC mode, it was then seen again by Audio MIDI Setup and the other software and the data type was then floating point.
So it appears that switching it to CC and back to non-CC did the trick.
Thank you for your help.
Dario
In the user manual about Class Compliant mode ( CC-mode)
Press and hold the two buttons SELECT and DIM during power-up lets flip normal-mode / CC-mode.
New Babyface Pro FS user here.......just did some comparison tests with the Roland and Steinberg interfaces I have been using for a long time......they simply can't keep up, coughing up artefacts and static when I try to match the RME buffer performance.
Also.....the loopback into OBS Studio is very simple, just use this ASIO Capture plugin https://github.com/Andersama/obs-asio
I use the asio plugin for OBS. It works well. It also works at our church so I can drop multitrack to the livestream from the a&h desk.
Nice little interface the the Babyface pro fs. I’ve had mine a few years now without any problems and TotalMix is great once you get used to it.
hi there whould you use the BFP main output EQ to calibrate for room acoustics? Nothing crazy, just a LF shelving and an other boost if needed. I don't want to spend for dedicated software for minor tweaks.
Yes, of course.
And you can save it as a user preset to one of the 16 user preset slots.
- Different unit.
https://forum.rme-audio.de/viewtopic.php?pid=228228Ok, I downgraded to HW203, but I'm currently too scared to turn the EQ on the headphone output. I'll be sure to post any changes. No noise on first restart.
May I ask if there's been any fixes for this noise issue in the latest firmware 2025-01-15?
No, see readme what changed.
@Hexspa
is the BF mode set to PC (not CC) ?
Thank you for your reply. I will download the file and look next time. Cheers.
@Hexspa
Yes, I'm pretty sure. Were it in CC mode, TMFX wouldn't work, correct?
Correct, and the question about CC seems unrelated,
A few days ago, I setup my Babyface Pro for a livestream and strangely, when I checked TM FX, there was no signal sent to the main outputs - only the headphones. The relevant faders were up but I still got nothing.
This was my first time experiencing this and it was a bit scary, especially with the added pressure of the livestream.
When I disconnected the USB cable and reconnected it, the signal was sent to the main outs as expected.
What could have caused this???
Hi all.
Please explain me this from Baby user manual:
DA, Line out 1,2 LR out.
DC @ 0 dBFS: 6.35mm 4.8 V, 3.5mm 2.4 V, XLR bal. 9.6 V
These are the Peak values.
https://sengpielaudio.com/AcousticKnowl … nswers.pdf
hi, checked posts on the forum, and also whole manual multiple times for how to remap OUT button to switch between monitors and headphones, and in the manual there is no reference to 'Options/Key Commands' settings dialogue
in the manual here (because it seems to not have version number): https://rme-audio.de/downloads/bface_pro_fs_e.pdf
on page 64 section '21.10 Menu Options' - paragraph 'ARC & Key Commands' does not contain 'See chapter 21.x.' text like other paragraphs do
so seems there is no way to see how the remapping dialogue actually looks like, and what are the current remapping options available
using ADI-2 DAC FS daily, with all the buttons remapped, this is very important information, to be able to customize the usage of BF FS in my second workstation workflow
i like the section '24.5 MIDI Control' for extended control, but it also does not hint anything towards monitors / headphone switching
my best guess is to just use 'Speaker B' bus, assign it to PH3/4 output, and use that for the switching between 'Speaker A' and 'Phones 1'
