Topic: Multiface II just stopped working, LED always on
After some initial troubles installing the thing, my Multiface II with a PCI-card worked flawlessly for some time. But today when I turned on the computer it just wouldn't work. The red LED stays lit, doesn't blink, it's lit constantly as it should be during the booting. Clicking on TotalMix or the control panel doesn't do anything, they don't open. In the device manager, there's the yellow exclamation mark next to the RME entry and under properties it says: "Your computer's system firmware does not include enough information to properly configure and use this device. To use this device, contact your computer manufacturer to obtain a firmware or BIOS update. (Code 35)".
I didn't change anything, this just happened out of the blue. Motherboard is a Gigabyte GA-EX58 running 64bit Windows 7.
Any ideas?
Thanks, David
