Topic: "Bug" in TotalMix with the Midi Implementation
Hi everyone,
I put this question/"bug report" in this folder because I am working with ADI 648 and Madi stuff, but I think its a general problem of TotalMix.
In my opinion there is a little "bug" in Totalmix with the midi implementation for the control of all simlpe not on/off messages described in chapter 31.5 in the manual
This "bug" affects all the buttons in TotalMix (DIM,MONO,TALKBACK,MONITOR MAIN,MONITOR PHONES an the PRESETS)
For example: If I want to control the DIM button via Midi:
the correct midi message(s) range must be (in hex) : 90 5D 01 up to 90 5D FF to toggle the button that means a midi NOTE ON message with a velocity greater then 00.
But the button only reacts when I send the following message (in hex) : 90 5D 00. The DIM button toggle again (off) when I send the message 90 5D 00 again.
That means the button only reacts when I send a Note On message with the velocity of 00 but
many keyboards and other midi equipment interprets a velocity of 00 similar to a NOTE OFF message.
So, if I want to work in connection with oher midi equipment I have the problem to translate the midi messages going to the Totalmix software "on the fly".
I solved the problem by working with the software ?Bomes Midi Translator?, but for me I think it can't be a big deal to change the behavior of Totalmix to a "correct" working, so that TotalMix reacts on Midi Note On messages with a velocity greater then 00.
It works so far, but I am interested in needing as few normaly unneeded softwaretools as possible in doing audio recording, mixing and mastering.
If you could change this little software "bug" in the next update of Totalmix I would be very glad.
Thanks!!
Peter
Sonoarte Limited
