Topic: Fireface UC sending unwanted MIDI messages in standalone mode
just got the UC and I'm quite impressed for quality and flexibility of the product.
There's a strange annoying behaviour though in standalone mode (it happens ONLY in standalone mode):
When I use the FFUC disconnected from the DAW or with the DAW turned off, the red "HOST" led lights, and I think that's expected.
The problem is that in that situation, when tweaking the rotary encoder in "level" mode I see some MIDI messages are sent through MIDI Out 1, and that's not good in my setup because I have a synth keyboard receiving MIDI from out 1 (some events are note on, so the synth produces sound in response).
"Enable MIDI control" is disabled on TotalMix, and the MIDI output port for controller is set to "NONE" so I would expect the FFUC should never send MIDI events by itself.
Moreover, the MIDI events are not documented.
It looks as if the same messages are sent out just after turning on the FFUC in standalone mode.
Firmware version is 91, but the problem also happens in 82.
Driver version is 0.935.
This is the detail of sent messages:
0: B0 37 0B [CC55] chan 1 val 11
1: E7 00 00 [Pitch Wheel] LSB 0 MSB 0
2: B0 36 01 [CC54] chan 1 val 1
3: E6 00 00 [Pitch Wheel] LSB 0 MSB 0
4: B0 35 0B [CC53] chan 1 val 11
5: E5 00 00 [Pitch Wheel] LSB 0 MSB 0
6: B0 34 01 [CC52] chan 1 val 1
7: E4 00 00 [Pitch Wheel] LSB 0 MSB 0
8: B0 33 0B [CC51] chan 1 val 11
9: E3 00 00 [Pitch Wheel] LSB 0 MSB 0
10: B0 32 01 [CC50] chan 1 val 1
11: E2 00 00 [Pitch Wheel] LSB 0 MSB 0
12: B0 31 0B [CC49] chan 1 val 11
13: E1 00 00 [Pitch Wheel] LSB 0 MSB 0
14: B0 30 01 [CC48] chan 1 val 1
15: E0 00 00 [Pitch Wheel] LSB 0 MSB 0
16: 90 07 00 [Note Off] chan 1 note 7
17: 90 06 00 [Note Off] chan 1 note 6
18: 90 05 00 [Note Off] chan 1 note 5
19: 90 04 00 [Note Off] chan 1 note 4
20: 90 03 00 [Note Off] chan 1 note 3
21: 90 02 00 [Note Off] chan 1 note 2
22: 90 01 7F [Note On] chan 1 note 1 vel 127
23: 90 00 7F [Note On] chan 1 note 0 vel 127
24: 90 17 00 [Note Off] chan 1 note 23
25: 90 16 00 [Note Off] chan 1 note 22
26: 90 15 00 [Note Off] chan 1 note 21
27: 90 14 00 [Note Off] chan 1 note 20
28: 90 13 00 [Note Off] chan 1 note 19
29: 90 12 00 [Note Off] chan 1 note 18
30: 90 11 00 [Note Off] chan 1 note 17
31: 90 10 00 [Note Off] chan 1 note 16
Is there something I can do to prevent the FFUC from sending all these messages or is there something wrong with the card?
Thanks,
Mario
http://www.reverbnation.com/errepici
