Topic: DAW outputs unexpectedly mute with MIDI input
Hey all.
Very happy owner of a Fireface 800 here, flawless operation so far, and the quality of the AD/DA is stunning.
I'm using an Alesis ION through the MIDI input/output, and every now and then, one of the DAW outputs unexpectedly mutes even though MIDI control isn't active. Even stranger, this doesn't show in TotalMix, and the only way I can fix it is to power the Fireface off and back on.
Here's a screenshot to show this issue:
You can see that there's audio coming from DAW 1 and 2, but only hardware output 1 is working.
DAW output 1 can pan across to the other output, and it works fine. I can route the audio in OS X to DAW 3 or 4, and route that to hardware output 2 fine. It's just DAW out 2 which doesn't work.
Hope this is enough information...
Ta,
Alex
