Topic: Fireface Mixer 2.71 Re-draw Errors
When changing presets on 2.71 (FF800 - it also happened with the previous version) the re-draw of the mixer isn't always correct. I can't for example click on "8" reliably. It moves around... as do some other numbers (like "4").
While I'm on the subject. Can you assign a keyboard shortcut for "talkback"? It would be truly wonderful if you could.
Thanks for continuing work on the most stable, reliable interface, I've ever had the pleasure of working with.
