Topic: 3.020 - Different latencies still possible with 2 Firefaces
I can still choose different Buffer Sizes for each Fireface unit sometimes.
I would tell exact steps how to reproduce this if I knew but I've seen this after 2nd unit has been turned off and later on again (without booting Windows).
System: 64bit W7, 2 x Fireface 800, latest drivers & firmware
-Panu
sonarmods.com
Re: 3.020 - Different latencies still possible with 2 Firefaces
Adding a second device live might not trigger the sync mechanism. Note that this second setting is not valid, it is just a display error. The setting of the first card/interface is the reference.
Thanks for the info!
-Panu
sonarmods.com
With the latest driver installed this is not possible. The second tab always reflects the latency settings of the first settings tab.
The display only bug has been fixed.
/Uwe
5
panu, if you see it again make screenshots of both settings and the about tab, and Uwe will owe you a beer or similar ;-)
I have 3.020 installed.
If both units are on when Windows starts up then values are always the same. But in case 2nd unit is turned on later values may not always be locked. Before 3.020 this was much easier to reproduce.
-Panu
sonarmods.com
Beer proof
Sorry about shaking camera - it's not easy to use PC and make decent looking adventure movie at the same time.
Includes hardware revision detection failure, too.
-Panu
sonarmods.com
8 (edited by panu 2010-09-17 18:08:33)
It was not only false buffer size that unit 2 derived.
Other settings were wrong, too.
Screen captures (first wrong values, then restored values from flash):
[img align=False settings]http://www.avaruusankat.com/etc/RME/false-settings-false.jpg[/img]
[img align=Right settings]http://www.avaruusankat.com/etc/RME/false-settings-should-be.jpg[/img]
This happened at the same start as I got the hardware revision detection failure.
sonarmods.com
Beer proof
MC, did you get your beer?
-Panu
sonarmods.com
10
No no, YOU will get the beer ;-)
Hey, I don't drink... Uwe shall offer you one ;-)
sonarmods.com
12
No beer drinker either...someone else? HeadScratch
I suggest one of MC's special cocktails, but only for MC (others might faint right away after the first sip).
I'll take espresso smile
sonarmods.com
