Topic: W7, Sonar 8.5.3 32-bit + 2xFF800 (3.020) - Recorded tracks not in sync
OK, I could not get WDM rocking and I'm back to ASIO. Here's one of the reasons why I wanted to try WDM. I have seen this behaviour many times in my current setup. It starts randomly when I'm doing multitrack recording with 2 FF800 units.
Units are in 'sync' but for some reason tracks with input channel from unit 2 come to Sonar a lot EARLIER than unit 1 tracks. Difference is approximately 5000 samples.
Audio Options - Advanced:
Driver Mode: ASIO
Dithering: None
[ ] Share Drivers
[ ] Use MultiProcessing (no effect)
[ ] Use MMCSS
[x] Always Open All Devices
[ ] Remove DC Offset
Manual Offset: 0 [x] Use ASIO Reported Latency: 557
Timur, Jeff, MC? I really need your help...
EDIT: Images removed to save space
