Topic: smux issue with HDSP 9652 and lucid 88192
I've set the lucid 88192 to smux on for both input and output. Hooked up all four adat cables to adat inputs 1 and 2 on the 9652 card. the hammerfall dsp settings show system clock slaved at 88.2, however adat sync shows ADAT 1 at 44.1. Should they both be the same?
I'm using reaper, and getting the mismatched sample rate white noise. the reaper project is at 88.2.
what am I missing?
thanks
