Topic: FF400 glitching, sounding half tempo
HI all,
I have the FF400 running from a mac book pro running OS 10.5.8
I also use Ableton 8.2.
I have recently started using the FF400, and it has been fine, until i started using the midi functions.
Today I had it plugged into a Machine Drum, and an APC 20 running via usb also talking to Ableton.
I was triggering machine drum sounds via ableton clips, and running about 25 channels of 16 bit 44.1 audio.
Every now and then, the FF400 would glitch out, with high squeely noises and it would sound like the music had slowed down to half tempo.
I thought it might be because I had not updated the firmware/drivers since installing the ones on the disk supplied, tried this, and got the message
Failed with error 20000000
Any ideas what might be the problem???
cheers all.
Evan
